ke36 lowering
ke36 lowering
Postby Josh » Mon Jun 15, 2009 8:57 pm
Im looking at lowering my ke36 soon. I want a 90mm drop, With the back leaves I was thinking of getting the leaves reset 40mm then running 2" blocks, but whats the deal with adding an extra leaf? lowering it this much i would want to stiffen the back up to keep it off the bumps, how would I go about adding a leaf? As for the fronts, would you reccomend compressing the original springs or proper lowering springs. What about getting custom springs made, at that height what weight spring would i wanna use? Any help would be much appreciated, Cheers
2tb kp60
Josh
Postby tsoob » Tue Jun 16, 2009 2:20 pm
yo josh, i have done a few of these now, best way is to do a match up for the front and there is a croud who do the leaf's here in auckland, i would seriously recomend you do some shocks at the same time
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Josh » Tue Jun 16, 2009 4:27 pm
Are you able to source me the springs and shocks for the front? And who do the leaves?
2tb kp60
Josh
Postby Josh » Thu Jun 18, 2009 6:29 pm
does anyone else know of any other ways to get it low
2tb kp60
Josh
