I'm having this crazy strange overheating problem. The symptoms are:
1) Car warms up really fast from cold start, like within 1-2mins of driving the needle will reach half. This progressed gradually from normal working order a few weeks ago till total overheating.
2) heater start to lose it's ability to provide heat, this progressed gradually as well - a quick blip on the throttle will bring heat back for a moment. Idling at the lights will make the heater cold, once get moving it'll be warm. now it's just total fail, cool breeze reguardless of engine and road speeds
3) car will overheat when stopped at the lights, this has been progressing gradually as well, from a quick blip on the throttle will fix it till now which revving does not help, even driving normally will cause the temp needle to reach 3/4 way up, and if continue it'll overheat.
4) cooling system loses a tiny bit of water and usually will need to top up every 2 weeks, but very little - about 100ml
Waterpump, cambelt is new since 5,000kms ago
Waterpump is some random brand
Did not use any anti-freeze since 10,000kms ago
There is signs of rust.
thermostat is new since 40,000kms ago
Did remove thermostat - no difference
rubber piping leading into and exit out from the heater core is cold, tested while tempreature needle is 3/4 into "hot" and heater on full hot.
Radiator is warm 1/5th way down from the top only, from then onwards is cold, tested during needle has reached 3/4 way into "hot".
Water pipe leading into radiator is quite warm
water exit out from the radiator is cold
Stuck garden hose into radiator - water is exiting freely at drain point.
Stuck garden hose into both heater core inlet and outlet, water flowing freely - did also the same on engine side - water flowing freely.
Blipped throttle with radiator cap off, there is signs of water movement although not severe.
Turned water pump by hand - smooth operation.
I suspect the waterpump has gone bad, but it's not leaking or making any whining noises, and 5,000kms since new, and i've read to have the waterpump blades all worn out it'll take YEARS of neglect?
If the radiator is 90% clogged, I'm sure the water outlet pipe will be hot?
It seemed like the car needs to be revved to keep cool, but now revving doesn't help anymore. A few days ago I have to drive in 2nd gear (automatic) to keep the car cool, putting it into drive the heat will start to creep up. But now it's not making a difference it's overheating reguradless.
Any ideas anyone?
