Crampy wrote:Are they interference? I thought all 4AGES were non-interference motors.
bluemaumau wrote:blacktops are interference engines too arnt they, meaning if youve got it wrong, your in trouble.
why didnt you just put all three pulleys at there markers? then youd have been sweet
TRD_ZERO wrote:Can timing be done like this as i figured it is exactly the same as before i took it all apart.
jondee86 wrote:even tho the crank is 360 degrees away from where it should be.
CAMB01 wrote:All 4ages are non interference including 20 valves.
