KinLoud wrote:I'm sure it was related to a sensitive/faulty knock sensor
~SlideWays~ wrote:KinLoud wrote:I'm sure it was related to a sensitive/faulty knock sensor
Partly explains why backing off the timing works. But not the relation to temperature - this could be an ecu setting to stop putting engine under load before it is at operating temp?
There could be a millions explanations, possibly relating to who built the pyramids, but either way mine was fixed via ign timing.
kompressor wrote:I fixed this by using an ae92 map ecu in my ae101 I opened up the ECU and chopped the internal wires. I re-soldered new wires inside the ecu as the pin-out is different.
I have also heard of some AE92s having the dip as well. So, it'd be a big pain in the Ar$e to rewire the ECU for it to just do the same thing.
themaleman wrote:I have also heard of some AE92s having the dip as well. So, it'd be a big pain in the Ar$e to rewire the ECU for it to just do the same thing.
remember not all ae92s r the same. as said above it sounds like the maped ae92s dont have the dip in power
