fivebob wrote:I suspect that this is the way it's supposed to be. However you can check for error codes by doing the following;Code(s) will be display on the temp display. If there is more than one code then press "FRONT" to cycle through them.
- With the ignition off simultaneously press AUTO & RECIRC/FRESH buttons.
- Turn ignition on.
Post any codes you get here and I will check what they mean.
brunch wrote:fivebob wrote:I suspect that this is the way it's supposed to be. However you can check for error codes by doing the following;Code(s) will be display on the temp display. If there is more than one code then press "FRONT" to cycle through them.
- Turn ignition on.
Hoolio sorry to hijack somewhat, but Fivebob is there any way to do something similar for a 97 Corolla BZ Touring wagon? Mine only blows full hot or full cold, nothing inbetween!
brunch wrote:is there any way to do something similar for a 97 Corolla BZ Touring wagon? Mine only blows full hot or full cold, nothing inbetween!
fivebob wrote:brunch wrote:is there any way to do something similar for a 97 Corolla BZ Touring wagon? Mine only blows full hot or full cold, nothing inbetween!
Sorry I don't know anything about them, but I wouldn't think so unless it has the same sort of control unit with LCD readout.
If it has a slider for temp control, and seperate push buttons for the airflow control, then I can't see any way it would be able to output error codes.
brunch wrote: Will check the cabin temp sensor tonight. Thanks
hoolio wrote:Fivebob,
That was interesting.
After all the LCD digits and LEDs went out after pressing the Auto & Recirc buttons, it displayed the number 21,(flashing), it also indicated the font vent (with the arrow & little 'man' figure) on the display......
I then hit the recirc button (to try to make the system return to normal) however & it seemed to run off and do some kind of self test programme counting up and running through all the vent configurations while running the fan at various speeds...
MAGN1T wrote:Yoy're wasting your time doing all that shyte unless you've reset it first to confirm that it's still not working properly.
Reset as in disconnect the battery.
fivebob wrote:Just checked and it does put out an error when there is no sunlight. That said however when I checked my car this morning to see that I had the instructions right, I didn't get a sunlight sensor error and it was an overcast day.
Like I said before I'm not even sure this is a fault. In other Toyotas I have owned bi-level air flow resulted in hot air at floor level and cold air out of the top vents.
