cedwards wrote:looking at fivebob's diagram the blow off valve actuator plumbing is how I would expect it to be, in reality unless i'm mistaken it is totally different with both pipes teeing into the same point on the manifold with a non return valve plumbed into the one..
Would this possibly be the cause of the normal flutter fivebob mentions?
I can't help but feel the diagram's plumbing is better than the actual plumbing for the blow off actuator?
cedwards wrote:Wouldn't the blow off valve work that much better if both chambers were plumbed to their respective sides of the throttle body as in the diagram while still leaving the VTV in place?
Users browsing this forum: No registered users and 27 guests
