Does this sound like a thermostat jammed open?
Postby snwtoy » Sun Jul 19, 2009 7:57 pm
During the cold snap about 4 weeks ago, when driving on the motorway for about 20minutes, the intake temp was reading 1-2 degrees. The car temp guage didn't even get to 1/4 (usually sits bang on half).
Driving around in milder temps, 10 degrees plus it does get to normal operating temp, but seems to take longer than our corolla. I've never really taken note of how long it takes to get to temp before I noticed the above anecdote.
Is it difficult / time consuming to change the thermostat on an ST215?
snwtoy
Postby Mr Revhead » Sun Jul 19, 2009 8:18 pm
sounds like it could be
how long to warm in normal conditions?
Postby snwtoy » Sun Jul 19, 2009 8:36 pm
Mr Revhead wrote:sounds like it could be
Well in current conditions at 7am in auckland, outside temp around the 10 degree mark it's taking about 15 minutes on my commute, which includes speeds up to 70km/h, but more often 30-50km/h
snwtoy
Postby Mr Revhead » Sun Jul 19, 2009 8:38 pm
yeah I'd be betting on stuck open stat.
Usually very easy to do on toyotas, but never done a 215 one.
when you get a new one, make sure you get a new oring/gasket!
good time to do coolant tooo ;)
Postby blitza » Sun Jul 19, 2009 10:33 pm
this is in the caldina? the rubber seal falls off the thermostat valve face and gets stuck either in the valve sealing area preventing the thermostat from closing, or just floats around inside your block. either way, temp is slow to build, much more of a problem in an auto, but still easy to fix.
MAD Industries Limited
blitza
Postby sergei » Sun Jul 19, 2009 10:51 pm
blitza wrote:this is in the caldina? the rubber seal falls off the thermostat valve face and gets stuck either in the valve sealing area preventing the thermostat from closing, or just floats around inside your block. either way, temp is slow to build, much more of a problem in an auto, but still easy to fix.
I have exactly same thing (piece of rubber off thermostat stuck in it), anyway if assuming ST215 is similar to ST205 in water department, then it is about 20-30min job in not so favourable conditions (ie in the drive way).
Postby snwtoy » Sat Jul 23, 2011 1:17 pm
Sorry to bump a thread from 2009, but I think I'll actually fix this tomorrow, weather permitting :lol:
Can anyone tell me where the thermostat is housed - ie what needs to come off to get to it?
If it's the problem that blitz refers to, do I need a new thermostat? Or just remove a rubber bit jamming it?
Cheers :D
Oh, and yes ST215 Caldina GT-T
snwtoy
Postby sergei » Sat Jul 23, 2011 2:47 pm
snwtoy wrote:Sorry to bump a thread from 2009, but I think I'll actually fix this tomorrow, weather permitting :lol:
Cheers :D
new thermostat if you are going to open the housing is a must (since it only cost $30-40).
The thermostat is under the alternator.
Might need to remove alternator for better access.
Definitely air duct for the alternator will have to come out, and coolant drained.
The thermostat housing is only held by 2 10mm nuts.
It is possible not to disconnect the radiator hose (as those clamps are real pain in the ass), and leave the housing attached to it.
When buying new thermostat (preferably Toyota) also get the O-ring for it.
Postby snwtoy » Sat Jul 23, 2011 4:54 pm
Thanks heaps sergei, exactly the info I needed :)
I'll probably get the thermostat from repco/supercheap (if only toyota was open on the weekends). I want to get the coolant flushed asap as I didn't realise how crappy it had gone, and don't think I'll have another chance before my roadtrip next weekend.
snwtoy
Postby Bling » Sat Jul 23, 2011 5:58 pm
Take note of which way around the thermostat fits too :wink:
Postby Adamal » Sat Jul 23, 2011 7:17 pm
BZG|Bling wrote:Take note of which way around the thermostat fits too :wink:
It'll go either way as long as you have a good hammer ;)
Postby snwtoy » Sun Jul 24, 2011 9:45 pm
Thanks for all the help.
Thermostat was jammed open with rubber internals as described above. I assume this is a common issue for 3S egines?
Got a thermostat from Repco which has no rubber internals so in theory won't jam again.
It only fits one way too, so that was easy to work out.
Alternator definitely has to come off unless you're rubberman. Which means the waterbottle has to come off too, as it blocks the top alternator bolt.
Filling the radiator is about the only time I wish I had a heat shield for the turbo - pretty nervous when you slosh a heap of water onto a hot turbo :)
snwtoy
Postby Lloyd » Sun Jul 24, 2011 10:50 pm
Repco ones are crap. Genuine ones aren't overly expensive.
And for future reference to test if your thermostat is stuck open, easisy way is to find a long-ish downhill road where you can just go down the hill in gear and stay off throttle. Temp gauge will drop if thermostat is stuck open. Hot day or otherwise
