Bigger cc injectos on N/A 4age BT
Postby kramer2202 » Sun Jul 19, 2009 9:11 pm
Hey just wandering if any one has put bigger cc injectors on a N/A black top and if it would be worth doing to a worked black top to help get more power?
kramer2202
Postby Mr Revhead » Sun Jul 19, 2009 10:26 pm
moved to tech where it belongs!
it would only be beneficial if the current injectors are not up to the job, and you re-tuned the ECU to suit.
What is this definition of "worked"?
Postby frost » Sun Jul 19, 2009 10:27 pm
blacktop injectors are quite big as they are, i dont think you'll max them out unless your pushing some serious cf. how much power are you making/wanting to make?
Re: Bigger cc injectos on N/A 4age BT
Postby tsoob » Mon Jul 20, 2009 10:24 am
kramer2202 wrote:Hey just wandering if any one has put bigger cc injectors on a N/A black top and if it would be worth doing to a worked black top to help get more power?
how big are you planning of going? you would need some pretty serious head work done to warrant this.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby FANGIN » Mon Jul 20, 2009 12:58 pm
Just out of curiosity, how many CCs are factory B/T injectors?
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby sergei » Mon Jul 20, 2009 1:07 pm
FANGIN wrote:Just out of curiosity, how many CCs are factory B/T injectors?
295cc/min @2.5bar (from memory)
Postby kramer2202 » Mon Jul 20, 2009 1:29 pm
shit didnt no the injectors were 295cc ill keep them and not worry bout going bigger and iv had port polish both intake and exhaust bigger cams shaved block and head with .8mm trd head gasket ,bought one of bazdas intake plenums 3angle valve grind and valve seats re cut
kramer2202
Postby AceSniper » Mon Jul 20, 2009 5:37 pm
stock ones should be fine.
I use 380cc? from a 1jzgte, but stock ones only maxout in the high rpm
AceSniper
Postby kramer2202 » Mon Jul 20, 2009 7:05 pm
AceSniper wrote:stock ones should be fine.
ok sweet and wat kinda rpm do they max out ?
kramer2202
Postby Quirky » Mon Jul 20, 2009 8:48 pm
standard blacktop is 8500 rev limit, so somewhere there
Hello There
Quirky
Postby frost » Mon Jul 20, 2009 8:56 pm
should be higher then that, if they didnt do the job at that rpm then there not very good with stock settings. i'd say about after 9600rpm. my rev limit was set a 9500 and they still did there job ok.
Postby Bling » Mon Jul 20, 2009 9:39 pm
Quirky wrote:standard blacktop is 8500 rev limit, so somewhere there
LOL got proof?
Maybe you got a limited spec one as every other standard blacktop cuts at around the 7800 mark.
Postby Dell'Orto » Mon Jul 20, 2009 10:33 pm
LOL got proof?
Dont blacktops redline at 8?
Postby AceSniper » Mon Jul 20, 2009 10:43 pm
they cut when they hit the red on the dash, but then silvertop pushes 8500...
all comes down to how much air is passing through not only the rpm :lol:
AceSniper
Postby Bling » Tue Jul 21, 2009 12:44 am
Dell'Orto wrote:Dont blacktops redline at 8?
Yes something in that region. If you go by the guage 8k, but certainly not 8.5k. I would have found that out by now if it was the case :lol:
Postby Quirky » Tue Jul 21, 2009 1:20 am
Well on my old BZR it would hit around 8300 before it wouldn't rev any higher. Wouldn't have a clue as to how accurate the gauge is.
Hello There
Quirky
Postby XSVWGN » Tue Jul 21, 2009 1:45 am
my brothers silvertop trueno reved out to 10000;) With the ignition in the trueno you can slowly turn the key around to off (from engine running) vey very slowly and it will turn off the eletrics and rev limiters but the engine will still run. You can hear it go past 7,8,9000rpm!!! its insane!
Not good for the engine clearly but the trueno is a piece of shit so gets a good thrashing!! As the engine were originally designed by Yamaha with moterbike essentials inmind i believe these things can rev out very far
Im sure someone will correct me if i am wrong...
Matt
2008 Kia rio - work car
XSVWGN
Postby Mr Revhead » Tue Jul 21, 2009 8:42 am
wat
Postby sergei » Tue Jul 21, 2009 9:33 am
XSVWGN wrote:my brothers silvertop trueno reved out to 10000;) With the ignition in the trueno you can slowly turn the key around to off (from engine running) vey very slowly and it will turn off the eletrics and rev limiters but the engine will still run. You can hear it go past 7,8,9000rpm!!! its insane!
Not good for the engine clearly but the trueno is a piece of sh*t so gets a good thrashing!! As the engine were originally designed by Yamaha with moterbike essentials inmind i believe these things can rev out very far
Matt
watwat?
Postby Boost_4_Life » Tue Jul 21, 2009 9:40 am
wow. definitely gonna try that one :roll:
The rally beast
The rally beast again!
Boost_4_Life
