Resistance For Speed Sensor (ABS/4WS)
Postby celica_xr9145 » Sun Jul 19, 2009 11:45 pm
Dont know if im using the right terms here but on the front left speed sensor for the 4ws, how many 'ohms' should it be approximatly?
Sorry if im not saying it right, i think its the same as an ABS speed sensor too.
Am going to borrow a multimeter but dont know how many 'ohms' is correct.
The problem is that the 4ws light has came back on AGAIN with the fault code pointing to speed sensor (41)
TBH its only a hunch thats its broken, i took a look at it but all looks ok, i gave it a clean but no good. Speed sensor ring is all clean and im going to check the wiring for any splits.
Im told that there are sensors in the back but since there has been damage to the front corner of the car before, im guesing something has been damaged.
Can anyone help?
celica_xr9145
Postby 1hypo3 » Mon Jul 20, 2009 8:32 am
around 1.1 to 1.4k ohms
1hypo3
Postby AE82 FXGT » Mon Jul 20, 2009 11:21 am
put your multimeter on AC then spin the wheel and youll get a voltage
AE82 FXGT
Postby matt dunn » Mon Jul 20, 2009 8:37 pm
and 99% of the time there is no visable problem with them,
usually internal fault in the lead or head.
Postby celica_xr9145 » Mon Jul 20, 2009 8:41 pm
thanks for the replies guys, still trying to find a multi meter to borrow.
As you said, there is no damage to the sensor so has to be inside :?
celica_xr9145
