ITB sizes
ITB sizes
Postby spinster » Fri Jul 24, 2009 9:32 am
Is there a difference in inlet size between 4age 16V & 20V itbs
I thought silvertops were 45mm and blacktops 50mm but have come across one that is 47mm
spinster
Postby xsspeed » Fri Jul 24, 2009 9:40 am
Postby spinster » Fri Jul 24, 2009 4:23 pm
thanks for that, plenty of info there but what I was meaning to ask is the measurement at the end where the trumpet is bolted to which will also be the i/d of the trumpet?
spinster
Postby Crampy » Fri Jul 24, 2009 4:33 pm
The Blacktop ones are 50mm at the end of the throttle, so need 50mm inside diameter trumpet (obviously).
Never measured a Silvertop, but I'd assume it's 47mm like the one you have.
Crampy
