The hiace has a new trick for me. On low speed it will only sometimes work
Wiggling the stalk doesn't do anything and when its not working the best way to get it working is turning them on high then while its moving still, put it on low and sometimes, only sometimes its will continue to work on low
When its working on low it doesn't cut out and the motor sounds normal
Dodgy relay maybe?
Help please
Hunt
