Ae85 rear end movement (or front something)
Postby rx7guy » Sun Aug 02, 2009 5:22 pm
Hey my ae85 had a damaged rear trailing arm bush, so I replace the lot with nolathane. Now it has something whackjob going on, I think in the rear.
It feels as if the diff moves when I lift off or accelerate on a corner. For instance the car will pull to one side, I will take the corner, feel a small lurch, then it will pull to the other side.
The new bushes were all nice and tight to put in, and visually they still seem to be fine. I cant seem to see any play with the panhard rod either when someone shakes the car.
Also seems to get axle tramp, its worst when entering my driveway which is slightly uphill. I'm not sure if its related. It is lowered with adjustables and has an adjustable panhard rod.
Does anyone have any idea what is going on? Any way it could be diff internals/axles?
The torque band is wide and the road is narrow
rx7guy
Postby jakesae101 » Sun Aug 02, 2009 5:27 pm
sounds panhard rod ish as the panhard rod tops the sideways movement of the diff and combats axle tramp
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby rx7guy » Sun Aug 02, 2009 5:30 pm
Yeah that is kinda what im thinking. I cant seem to get it too move by hand though and it looks fine.
rx7guy
Postby frost » Sun Aug 02, 2009 5:38 pm
to fix axle tramp you need traction brackets on the lower arms,
the side to side will be panhard rod. most likely bush is worn/cracked
Postby rx7guy » Sun Aug 02, 2009 5:47 pm
Ok. Will pop it off and have a good look.
rx7guy
Postby rx7guy » Tue Aug 04, 2009 5:36 pm
Had a look, and the hub can move in and out on both sides a little. Is that wheel bearing? It was running low on diff oil before, would that have had an effect?
Edit: Just went round the block and its sounding horrible, clunks whenever I start, stop or go over a bump and a bit of whirring too.
What's munched?
rx7guy
Postby d1 mule » Tue Aug 04, 2009 8:36 pm
sounds like the diff man, i brought a ae85 recently with those exact symptoms, replaces the diff head and was mint
d1 mule
Postby fangsport » Tue Aug 04, 2009 9:31 pm
frost wrote:to fix axle tramp you need traction brackets on the lower arms,
not always, especially if the car is close to standard height
too soft rear spring will cause tramp as well.
an offset diff due to lowering can cause it as well.
never tried those tractions brackets, but making top links adjustable worked a treat on my Levin
fangsport
Postby rx7guy » Tue Aug 04, 2009 9:38 pm
Ohyep. How much oil meant to be in it? Fill to the plug on the side?
rx7guy
Postby fangsport » Tue Aug 04, 2009 9:40 pm
rx7guy wrote:Ohyep. How much oil meant to be in it? Fill to the plug on the side?
level to filler bung on rear bowl
fangsport
Postby frost » Tue Aug 04, 2009 11:23 pm
from the pics on garage dori his car is much lower then stock,
d2 come with 6kg rear springs.
he has adjustable panhard rod, so i assume he has centered his diff.
adjustable top links is a good idea too.
Postby fangsport » Wed Aug 05, 2009 12:08 am
should have also mentioned too stiff rear springs can cause tramp, although 6kg seens to be the norm for AE/TE rear, it is probably too rigid for most road applications.
fangsport
Postby frost » Wed Aug 05, 2009 12:30 am
fangsport wrote:should have also mentioned too stiff rear springs can cause tramp, although 6kg seens to be the norm for AE/TE rear, it is probably too rigid for most road applications.
yeah that sounds right to me. problem with the d2 stuff is even though they have heaps of damper adjustment you never get it right no matter what you set it at. too soft is too soft and a little harder is too hard :?
i have 4kg trd rear and that's still too hard coming off speed humps and stuff.
way too stiff for such a light rear end on the road.
Postby jondee86 » Wed Aug 05, 2009 8:37 pm
rx7guy wrote:Edit: Just went round the block and its sounding horrible, clunks
What's munched?
Had a car that broke the crownwheel carrier, and it behaved like that.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby rx7guy » Sat Aug 08, 2009 4:04 pm
So far i have decided the diff is still making a few noises and has slightly worn wheel bearings, but that is ok. It just was especially bad the other day it seems. The panhard rod is tight, and I think the rear end is secure.
After some more driving it now seems that if I turn the wheel and then drive straight the car pulls in the direction I turned. After time the pulling eases off. At any time if the steering wheel is straight, the car is driving straight though.
Ive had it at firestone for a wheel alignment and the guys there have checked everything is tight and set up and dont know why it is behaving like it is.
It has powersteering which I installed recent-ish, is it possible there is pressure somehow trying to turn the wheels? Have i put a valve or something in the wrong way round?
rx7guy
