oxy sensor
oxy sensor
Postby avinesh » Tue Aug 04, 2009 10:22 pm
is the oxygen sensor required if you run a after market ecu that has been tuned on the dyno???.....ecu is haltech e11v2...cheers
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby fivebob » Tue Aug 04, 2009 10:23 pm
no
Postby avinesh » Tue Aug 04, 2009 10:24 pm
fivebob wrote:no
lol that was fast, cheers for that man
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby XS1V » Wed Aug 05, 2009 9:48 am
Good for data logging if your ECU does that though :)
Brad
ST205 Group A Rallye #2363
XS1V
Postby avinesh » Thu Aug 06, 2009 1:17 am
XS1V wrote:Good for data logging if your ECU does that though :)
Brad
yea it does
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby t0ms » Thu Aug 06, 2009 7:09 pm
you dont have to but you wont have closed loop conmtrol of the fuel mixture. ok for a race car as your not worried about mileage but useful in a road car as the computer will use it for lean cruise adjustments
t0ms
Postby fivebob » Thu Aug 06, 2009 7:17 pm
Most aftermarket ECUs don't support, or have very limited support for closed loop operation.
Even if it does support closed loop in most cases it's not worth running a wideband sensor because they have a very limited life (same applies to datalogging), and narrowband is only good around stoich, so it's only usefull around idle or very low load.
