oil return
oil return
Postby deaf_rattle » Wed Aug 05, 2009 5:14 pm
What size/type of fitting should i get welded onto my sump for the turbo oil return?
Any info would be appreciated.
Postby Lloyd » Wed Aug 05, 2009 6:42 pm
A bit of pipe the size of the oil return line from your turbo. Cut hole. Weld in
Postby steve murch » Wed Aug 05, 2009 7:46 pm
depending on size of turbo the bigger the better
t3 size turbo should be no smaller than 19mm pipe,no tight bends or rubber bends that aren't designed to used on turbos,they collapse under heat.
oil doesn't come out of a turbo as a liquid its look more like candy floss thus that's why you need a bigger return pipe than feed.
steve murch
Postby deaf_rattle » Wed Aug 05, 2009 7:51 pm
steve murch wrote:depending on size of turbo the bigger the better
thanks Steve, turbo is an alltech sourced GT3582R.
Cully has suggested an earls type fitting, just gotta work out the size.
Postby steve murch » Wed Aug 05, 2009 8:56 pm
be carefull as the hole size in dash fittings arent that big for the hose size
steve murch
Postby Py7h0n » Thu Aug 06, 2009 10:01 am
Don't use a earls fitting if you can avoid it. They are overpriced for something that can be done a lot easier.
Py7h0n
Postby cat007 » Thu Aug 06, 2009 5:27 pm
Py7h0n wrote:Don't use a earls fitting if you can avoid it. They are overpriced for something that can be done a lot easier.
you can talk mr "I shop at cardwells and pay 4 times the price for fittings" :P
Postby jakesae101 » Thu Aug 06, 2009 5:59 pm
python is trying to avoid it just look
http://www.warzone.co.nz/pictures/HeadT ... 0032in.jpg
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby deaf_rattle » Thu Aug 06, 2009 6:04 pm
that turbo looks like the one that mightve given birth to mine.
thats massive!
