Locating The IACV
Locating The IACV
Postby celica_xr9145 » Fri Aug 07, 2009 12:53 pm
My cars having trouble starting when cold so going to clean out the idle control air valve.
I think i found it but before i pull it off, is this it?
It has 3 hoses connected to it and 3 sensors (i think there sensors)
My Haynes manual is useless
By the way, its a 3sge on a celica st183
celica_xr9145
Postby Akane » Fri Aug 07, 2009 12:57 pm
It's the white square thing with 2 screws, it's located in the top/right corner in the first pic, with 1 grey plug to it.
Postby celica_xr9145 » Fri Aug 07, 2009 5:39 pm
Akane wrote:It's the white square thing with 2 screws, it's located in the top/right corner in the first pic, with 1 grey plug to it.
thanks, i see it now, i took the grey plug and the yellow bit off, the actual IAC that needs to be cleaned goes underneath the throttle body and cant get the screw driver underneath to get :evil:
Will try again tomorrow
Thanks
celica_xr9145
