Opening e51 box.
Opening e51 box.
Postby Paulio » Tue Aug 11, 2009 1:27 pm
Hey,
I wana have a play 'round with an e51 box that I have, does anyone have or know where a manual may be, or some basic instructions?
Havnt played with gearboxes much as im not in to that sort of work, but am keen to get in to it.
Any help appreciated.
Paulio
yees booy
Paulio
Postby gasman » Tue Aug 11, 2009 1:44 pm
When I pulled mine apart for the first time I used a ae92 repair manual which had a overhaul section for the c52 box and it was almost identical apart from a few locational items.
"What can possibly go wrong?"
gasman
Postby Mr Revhead » Tue Aug 11, 2009 2:46 pm
have a search on toymods
someone there was translating the manual
Postby Akane » Tue Aug 11, 2009 4:13 pm
If it's anything like the MR2 box that I had, then you'll need to take the end section cover off, and use a 5th gear puller tool, then take out the casing, PITA tbh.
Postby Bazda » Tue Aug 11, 2009 5:12 pm
Its the same as a MR2 box, only thing different is the shifter.
Ideally you need 2 pullers. A gear puller and jaw pullers.
12mm socket
14mm socket
5mm allen key
24mm socket
big cresent
30mm socket and rattle gun
pliers
hammer
c-clip removers
5th gear can be quite difficult to install back on, for a first timer it would drive you crazy.
Postby Paulio » Tue Aug 11, 2009 5:54 pm
Thanks guys, barry. Very good.
May invest in some pullers tomorrow then, everything else I have. Ill get 5th gear off and see how it goes after that.
Paulio
yees booy
Paulio
Postby gasman » Tue Aug 11, 2009 7:43 pm
Bazda wrote:5th gear can be quite difficult to install back on, for a first timer it would drive you crazy.
Big hammer, or even bigger hammer usually works
gasman
Postby Bazda » Tue Aug 11, 2009 8:06 pm
I mean for aligning the syncro and snycro hub with the clip.
Postby AceSniper » Tue Aug 11, 2009 8:54 pm
just sore this it could be of some help to you....
http://www.snimoc.com/LSDTransmission.html
AceSniper
Postby Paulio » Tue Aug 11, 2009 9:30 pm
Sweet find, cheers bro!
P
yees booy
Paulio
Postby 85AW20v » Tue Aug 11, 2009 11:20 pm
This might help you out too.....
http://www.ae92gts.com/ae92gts_trans_rb_1.html
See ya
Simon
85 MR2 20v
85AW20v
Postby Paulio » Fri Sep 04, 2009 1:02 pm
Barry what are the pullers you use? i have tried 2 so far and they dont fit.. first was a 6" 3 arm that was dreaming and the second is a (called usa type) 3" 2 arm on a horizontal bar but the heels on the feet are too fat to allow it to fit in the grove on the gear.. I could grind the heels down but that would compromise the strength of the ankles, if you get what I mean.
im getting jonesway tools btw, bnt is the only place round here that has a range of pullers to order in.
cheers!
yees booy
Paulio
Postby Bazda » Fri Sep 04, 2009 1:54 pm
One of these sets for the small gear by it self.
Used the top left hand gripper thingy
Postby Paulio » Fri Sep 04, 2009 2:26 pm
Lol I shouldnt have asked.
Dare I ask how much and where from?
yees booy
Paulio
Postby Bazda » Fri Sep 04, 2009 2:50 pm
Paulio wrote:Lol I shouldnt have asked.
Those ones there are from sulco, the ones I use are a cheaper brand, no idea where they are from though..
Postby AceSniper » Fri Sep 04, 2009 7:26 pm
top left is a bearing separator
On c series I use a harmonic balancer puller to remove 5th syncro hub
and a cheap $20? 3jaw puller from supercheap with the heal ground down haven't had any strength issues just make sure your pulling off square
AceSniper
