annoying vibration
annoying vibration
Postby groupagt4 » Sat Aug 15, 2009 3:27 pm
ive got a really big annoying vibration in my trueno around 3000rpm and again at 5000rpm getting on and getting off the gas. ive checked that all bolts in the driveline is tight and ive rotated the propshaft around. still nothing. has anyone had this problem before
groupagt4
Postby Paulio » Sat Aug 15, 2009 5:25 pm
Yeah on an old hack corona, didnt bother to fix it 'cause that was ganstra vibration 8)
Checked the pulleys? Possibly a pulley bearing naffed or loose bolt?
Get under the bonnet, hold the throttle and rev it so you can find where its comming from, if its from the drivetrain or the engine atleast.
P
yees booy
Paulio
Postby Bazda » Mon Aug 17, 2009 9:33 am
exhaust mounts / Exhaust
Postby THA SHZ » Mon Aug 17, 2009 11:03 am
check your rear engine mount , mine did this in my corollas whenevr they were naffed 8)
THA SHZ
