I think I need to replace my 02 sensor and was wondering if you guys know if I can use an o2 sensor from a different Toyota? (or better yet a universal denso one) the caldina part number is 89465-21030.
Although my car is running well I think the o2 sensor heater is not working properly as I'm getting a check light as soon as my engine temp goes up. I'm throwing a code 21 which is either o2 sensor or abnormal heater signal but the car (once it's warmed up) is running fine and the AF from my UEGO Wideband is pretty close to 14.7 (again when it's warmed up) so I think it's the heater and not the o2 sensor.
R
