3sgte not idling properly
Postby thirdkid » Mon Aug 17, 2009 8:41 pm
Posting in behalf and sorry if repost
My mate has a mr2 with a 3sgte engine. It starts but wont idle and he can rev it up to 2000rpm and itll run but if the revs go below that the engine dies.
The mods hes done are free flow s/s extractors, intercooler, aftermarket downpipe and exhaust, 8mm leads. The problem started when he replaced the extractors, down pipe, and intercooler.
Could it be a vacuum leak? And what should be checked?
thirdkid
Postby levinguy » Mon Aug 17, 2009 8:46 pm
how does it run above 2000rpm? smooth or rough?
i would be looking for a vaccum leak
levinguy
Postby thirdkid » Mon Aug 17, 2009 8:52 pm
its running rough
thirdkid
Postby celica_xr9145 » Mon Aug 17, 2009 8:54 pm
my celica sometimes does this when cold, hasnt been so bad since i gave the spark plugs a wee clean, hasnt cured it though :?
celica_xr9145
Postby thirdkid » Mon Aug 17, 2009 8:56 pm
hmm, when the car was bought one of plugs was pretty much drowned in oil. But has been fixed and the plugs were changed also.
thirdkid
Postby fivebob » Mon Aug 17, 2009 9:02 pm
Which model SW20?
If it's the AFM version (pre Oct '93), then several things could be wrong, but Vacuum/Boost leaks would be high on the list, as would a fault in the AFM wiring.
Postby thirdkid » Mon Aug 17, 2009 9:09 pm
yeah 2nd gen sw20. We are going to redo intercooler piping and extractors. Also it could be the airflow meter right? Because this was replaced before
thirdkid
Postby XS1V » Tue Aug 18, 2009 10:10 am
AFM would be a good bet on this one, is the computer spitting out a check light?? On one of the Gen 2's Ive had, it did exactly this, changed AFM and ran perfect. Would definitely look for I/C plumbing leaks though also.
Brad
ST205 Group A Rallye #2363
XS1V
