there are two types of ae101 ITB's
or more accuratley two type of inlet manifold
got some pics somewhere... i'll dig em out later
one is a better shape
I don't think the ports match, but i reckon it would work quite well if you port matched them
the black top ones are HHUUUGGGEEE. too big for a 1600
the single biggest advantage the blacktop has over the silvertop is the tune
the stock tune on the 101 is not the best, you can get massive gains just by doing that alone. more than you would by putting on a blacktop head
http://s3.photobucket.com/albums/y82/Mr ... ock%20ecu/
some pics of my dyno plots there, done same day back to back. pics are of the best of 2-3 runs on each ecu
ignore the actual figures for anything other than a reference to those two plots..... the dyno was waaaaaaaay under reading
