New car arrived: Couple of questions (1994 Toyota Levin)
Postby DXROLLA » Sat Aug 22, 2009 8:06 pm
Hey i picked up my 1994 Toyota Levin today (silvertop 20v)
There a couple of things wrong with it, 1st being an oil burning smell not real bad just get a woof of it every now and again, have had a look under the bonet and all i can see is a greasy oil patch around the oil filter? Is this a commen problem?
Two being a slight knock coming from the rear im thinking maybe warn shocks?
Its also running one of those hks type foam mushroom filters, im guesing i should ditch this?
And thats about all for now, im very happy with how it goes alot quicker than the old starlet lol 8)
DXROLLA
Postby jakesae101 » Sat Aug 22, 2009 8:13 pm
is it a superstrut model? in my ae101 trueno id get the burnt oil smell too but i sold it before i found out what it was ditch the mushroom filter they become britle and you suck the foam into the engine
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby DXROLLA » Sat Aug 22, 2009 8:17 pm
No not superstrut, well it has no stickers saying so anyway.
Yeah i had the burnt oil smell in my wrx i had and it was leaking a bit of oil out the front of the engine. So im guesing it has a leak somewhere is there any commen places to look?
DXROLLA
Postby l1ttle_d3vil » Sat Aug 22, 2009 8:25 pm
DXROLLA wrote:So im guesing it has a leak somewhere is there any commen places to look?
All the 16v 4ages I've had leak oil out the dizzy, drops onto the exhaust manifold and smells like the car is on fire, only takes one drop of oil to smell real bad. It'll burn off after a while though, until the next drip :lol:
Postby jakesae101 » Sat Aug 22, 2009 8:28 pm
accept its a 20v 4age
jakesae101
Postby Mr Revhead » Sat Aug 22, 2009 8:47 pm
has it got an oil catch can?
Postby rollaholic » Sat Aug 22, 2009 10:07 pm
those oil filter housings have about three different seals in them, and its in just the right place to drip onto the exhaust
Postby Mr Revhead » Sat Aug 22, 2009 10:14 pm
actually thats a very good point ^
Postby 0EBUNY » Sat Aug 22, 2009 11:40 pm
yea i say check that the oil is not leaking out the filter seal.
new project
1998 toyota altezza :D where do i start plans go for miles
0EBUNY
Postby DXROLLA » Sun Aug 23, 2009 2:17 am
Yeah il do an oil and filter change soon see if i can spot anything.
Also it tends to idle quite high sometimes it can be as high as 1500-1600rpm or drops to around 1000rpm, any ideas on what this could be?
DXROLLA
Postby Mr Revhead » Sun Aug 23, 2009 10:07 am
look before you take the filter off
removing the filter on those drops oil in exactly the place you need to look to see if its leaking. so if you take the filter off first, you wont be able to tell if its leaking
Postby andyztouring » Sun Aug 23, 2009 10:14 am
Re your idle-does the temp sit low on the open road? if so thermostat requires replacing.that lets the computer turn off cold fast idle. For the rattle in the back .I think its the sway bar bushes go on these,someone will correct me,it is a common fault on these cars.
andyztouring
Postby 1hypo3 » Sun Aug 23, 2009 10:33 am
andyztouring wrote:Re your idle-does the temp sit low on the open road? if so thermostat requires replacing.that lets the computer turn off cold fast idle. For the rattle in the back .I think its the sway bar bushes go on these,someone will correct me,it is a common fault on these cars.
me agree, with swaybar bushes and the oil leak change the filter -try and use a genuine filter as aftermarket ones tend to leak and wash it down and keep an eye out to see if it still leaks
1hypo3
Postby Mr Revhead » Sun Aug 23, 2009 10:39 am
its not the filter that leaks, while its possible it could be, there are orings in the filter housing that leak
Postby AceSniper » Sun Aug 23, 2009 11:10 am
rear swaybar bushes are wear and tear and do cause a knock
AceSniper
Postby DXROLLA » Sun Aug 23, 2009 12:46 pm
Sweet that is exactly the problem with the fast idle it does run cold on the open road i thought that was a bit weird aswell.
Il have a good look to see where the oil is coming from it looks to be around the filter housing which would make sence with the burning smell aswell as it is above the exhaust.
Will check the sway bar bushes aswell, i gues it would be a good time to upgrade to some nolathane ones?
DXROLLA
Postby DXROLLA » Sun Aug 23, 2009 3:28 pm
Also there is a blue switch above the bonnet release, any idea on what this could be ive turned it on and it lights up but nothing seems to turn on that i could see
DXROLLA
Postby Bling » Sun Aug 23, 2009 6:31 pm
The switch could be for anything , try and trace the wire to work that one out.
Postby BigDon » Sun Aug 23, 2009 11:46 pm
On an ae101 I had the O ring seals went on the oilfilter adaptor plate and it started leaking. The seals are cheap and pretty easy to replace when doing a filter change
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby Boost_4_Life » Mon Aug 24, 2009 8:35 am
yea + 1 for oil fiter housing seals. I just did mine on the starlet as they were leaking quite badly. real easy to replace.
The rally beast
The rally beast again!
Boost_4_Life
