4age 16Valve Block & Head Light Mods
Postby gepsk8 » Tue Aug 25, 2009 7:50 pm
so plan is to build up replacement motor for GTI(fxgt) running Smallport 4age
so plan is to run Replace bearings, rings, seal etc,
Block Work
i was looking at changing the crank to silvertop (heard there got smoother surfaces for faster oil draining??)
Silvertop rods lighter
Standard Smallport pistons 10.5
TRD 0.8 Head Gasket to bring up compression
little bit blueprinting
Maybe replace oil pump??
Head Work
smoothing out ports
Bluetop cam Worth fitting?
Hydraulic lifter worth fitting??
Valve Seal, Etc
Any mods people know work or Recommend??
Already Running lighted flywheel
O272754663
gepsk8
Re: 4age 16Valve Block & Head Light Mods
Postby Crampy » Tue Aug 25, 2009 8:17 pm
gepsk8 wrote:i was looking at changing the crank to silvertop (heard there got smoother surfaces for faster oil draining??)
Same crank, so no point changing it.
Crampy
Postby Mr Revhead » Tue Aug 25, 2009 8:38 pm
thats a new one!
Postby crispy'86 » Tue Aug 25, 2009 8:44 pm
Possibly run bluetop cams, i'm not sure if they're any different to smallport ones. I would have thought smallport heads flow well enough, the only reason you'd change the characteristics was if you ran a large duration cam. Somebody reckoned you can shim the 20v oil pumps to give them more/higher flow pressure if you were to replace them. Definitely TRD gasket for a good performance gain, definitely replace at least the valve stem seals. Be worth checking the valve guides too. (Something i just thought of while on this subject, i really should get thinking of that are some bore gauges to do more precise measurements)
What block work would you look at doing? I'd definitely suggest a surface of the block so your gasket seals properly and not have future troubles (a common fault i've found with many of the blocks i've had all of the 4a family
crispy'86
Postby Bazda » Tue Aug 25, 2009 11:33 pm
Shimming the oil pump up does not give it more flow, it just changes the point where the relief valve operates.
The stock valve will open at around 70-80psi. shimming it up will make it open later.
Postby tsoob » Wed Aug 26, 2009 12:14 am
gepsk8 wrote:so plan is to build up replacement motor for GTI(fxgt) running Smallport 4age
Block Work
Head Work
smoothing out ports
Valve Seal, Etc
what you wanna achieve with your engine mate (power etc)?
what u gonna use it for (drag track?)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby crispy'86 » Wed Aug 26, 2009 7:34 am
Bazda wrote:Shimming the oil pump up does not give it more flow, it just changes the point where the relief valve operates.
That's one of the more "Interesting what people say" comments, i didn't take that to gospel, just putting it out there as a comment someone reckoned. I wasn't totally convinced it'd not make too much difference to flow.
crispy'86
Postby gepsk8 » Wed Aug 26, 2009 9:21 am
just replacing my tied old motor, in my daily runner. running standard ecu.
wanted to do some small mod to gain light bit more power & reliability.
O272754663
gepsk8
Postby escortman » Wed Aug 26, 2009 2:42 pm
just get the smallport head tidied up, whack some bluetop cams in (slightly higher lift and longer duration) def makesure to get head skimmed and block decked and use a trd headgaskit
4x4 toyota blizzard offroader
escortman
Postby gepsk8 » Thu Aug 27, 2009 9:12 am
Silvertop rods
TRD 0.8 Head Gasket
Bluetop cams
are to only mods people recommend ??
O272754663
gepsk8
Postby KinLoud » Thu Aug 27, 2009 9:17 am
Late smallport engines have the silvertop rods from factory.
Postby Mr Revhead » Thu Aug 27, 2009 10:26 am
^ correct
only engine I would bother changing rods in would be a black top.
especially as your building a road engine
Postby Quirky » Thu Aug 27, 2009 12:23 pm
Forgot where I read this, but Bluetop cams give a gain of 2kw ATW over the stock smallport items, though it shifts the powerband quite a bit...
Hello There
Quirky
Postby tsoob » Thu Aug 27, 2009 1:17 pm
gepsk8 wrote:Silvertop rods
TRD 0.8 Head Gasket
Bluetop cams
bolt on a turbo is what id recomend 8)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Dell'Orto » Thu Aug 27, 2009 1:40 pm
Quirky wrote:Forgot where I read this, but Bluetop cams give a gain of 2kw ATW over the stock smallport items, though it shifts the powerband quite a bit...
So effectively pointless then? Would much rather have 2kw less and have peak torque 1000rpm lower.
Postby ChaosAD » Thu Aug 27, 2009 2:15 pm
I'd add ARP rod bolts to the list, and an oil pressure gauge would be worthwhile.
I have read that the blacktop crank is the same part number as the earlier ones, but toyota called for closer tolerances during manufacture. I dont believe it would be worth changing though.
ChaosAD
Postby pc » Thu Aug 27, 2009 2:42 pm
I reckon valve grind, new rings & bearings, plane head & block flat, 0.8mm TRD HG.
Check all clearances.
Cheap & reliable, fast enough without spending any real money.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Mr Revhead » Thu Aug 27, 2009 2:52 pm
ChaosAD wrote:I'd add ARP rod bolts to the list, and an oil pressure gauge would be worthwhile.
they would change the part number if they changed any aspect at all of the crank.
any part that gets any change, will have a new part number.
and an easy way to check that would be to check the manuals on the clearances and bearing sizes
Postby ChaosAD » Fri Aug 28, 2009 2:27 pm
It is interesting to note that all the late model, large crank pin cranks-shafts are identical, i.e., same Toyota part numbers. However in reviewing the maintenance manuals, Toyota calls out much tighter inspection tolerances in the last generation 20 valve. The obvious reason would be to keep parasitic friction and vibrations to a minimum due to the difference in max engine speed that the 20 valve engines were allowed to turn versus the 16 valve ones.
http://www.club4ag.com/faq_and_tech_pages/4A-GE%20Crankshaft%20-%20Detailed%20Specifications%20and%20Analysis.html
ChaosAD
Postby Mr Revhead » Fri Aug 28, 2009 4:10 pm
oh yep, so tigher tolerances for wear in the service book
