Recondition Power Steering Hose
Postby celica_xr9145 » Fri Aug 28, 2009 2:02 pm
Got a leak on the high pressure power steering hose with the joints on it.
Ive been trying to get hold of a new one but easier done than said and dont really want a 2nd hand one of trade me unless i have too.
Is it possible to get it reconditioned or resealed?
If so, where do i go and how much am i expecting to pay?
(pic makes the leak look much smaller than it is)
If you look at the 2nd picture on the left, its coming out from where the hose meets the joint.
Thanks
celica_xr9145
Postby tsoob » Fri Aug 28, 2009 2:24 pm
i use pirtek hoses for all these kind of jobs, 0800 pirtek they are really good and will come to you. reasonably priced as well
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Mr Revhead » Fri Aug 28, 2009 2:30 pm
yeah any hydraulics place should be able to do it
pirtek, ryco, hydralink etc etc
they will need your old hose as they will probably have to re-use the fittings
Postby 2LTR Rona » Fri Aug 28, 2009 2:36 pm
Mr Revhead wrote:they will need your old hose as they will probably have to re-use the fittings
and by this Rev means you will have to drain all your PS fluid and then bleed again once new hose is back on
2002 Altezza, 1974 KE25
2LTR Rona
Postby CAMB01 » Fri Aug 28, 2009 3:26 pm
Just did that hose on a celica at work last week. Its fun trying to get it out. You have to remove the power steering pump to get it out, which means removing the drivers side axle to get the pump out.
You wont be able to get the hose off the pump in place due to the way the pump is mounted.
Must be common problem with them, they leak quite regularly.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby celica_xr9145 » Fri Aug 28, 2009 3:37 pm
thanks for the replies, unfortunatle there's no pirtek in dunedin but there is a hydraulink so will give them a call.
Ive helped my dad bleed his power steering system so thats not a problem 8)
celica_xr9145
Postby celica_xr9145 » Fri Aug 28, 2009 3:38 pm
CAMB01 wrote:Just did that hose on a celica at work last week. Its fun trying to get it out. You have to remove the power steering pump to get it out, which means removing the drivers side axle to get the pump out.
Really, how much did you charge to do that?
Shame i cant just seal it up with something :?
celica_xr9145
Postby CAMB01 » Fri Aug 28, 2009 3:40 pm
Sorry cant tell you that, i was just doing the job. There were other things as well i did on the job, the shaft had to come out anyway as was doing cv boots, so it was easy.
The one i did was leaking throught the cords in the hose, not out of the fitting.
You wont be able to seal it up, with it being on the high pressure side.
CAMB01
