wheel hop
wheel hop
Postby avinesh » Sat Aug 29, 2009 12:49 am
yea i have the dreaded wheel hop issue.......getting subframe bushes done next week, car is a 94 supra rz manual. Just wana know what you guys think is causing it, i thought its subframe bushes coz when i shift into 5th gear or any high gear while cruising there is a thud sound from the back, so thought hmmmm could be the whole subframe that moves a little but it still handles well no unusual handling. Wheel hop is realy bad when you shift from 1st to 2nd....Has stock beilstein shocks with tein springs car didnt wheel hop with this setup before it started doing this after a while....have destroyed a diff already coz of this :cry:
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby Mr.Phreak » Sat Aug 29, 2009 1:01 am
This is what Neil sorted out for the Soarer boys (http://soarercentral.com/sc-forum/messages/441/113542.html?1188096466)
Mr.Phreak
Postby avinesh » Sat Aug 29, 2009 1:15 am
Mr.Phreak wrote:This is what Neil sorted out for the Soarer boys (http://soarercentral.com/sc-forum/messages/441/113542.html?1188096466)
thats sub frame mounts right???
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby postfach » Sat Aug 29, 2009 3:15 pm
Looks similar to "drift pineapples". I would imagine you'll get the same/better result by replacing the rear subframe bushes with nolathane ones.
There's a guy on here.... I think his name is Ronnie (I'm sure someone else on here will know what I'm talking about) I know he does them for MKIII supras, maybe he also does MKIV/JZZ30?
postfach
Postby postfach » Sat Aug 29, 2009 3:22 pm
http://otomoto.com.au/kkr/alignment/index.html
According to this thread those pineapples will also fit your car and fix the problem.
postfach
Postby avinesh » Sat Aug 29, 2009 6:45 pm
what are cradle mounts???? Is that the subframe mount or diff mounts???
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby MrOizo » Sat Aug 29, 2009 10:49 pm
I remember reading that some times it can be the engine mounts. Are you sure these are in good condition?
MrOizo
Toyspeed Legend
Postby avinesh » Sun Aug 30, 2009 12:38 am
MrOizo wrote:I remember reading that some times it can be the engine mounts. Are you sure these are in good condition?
In a rwd will it cause real bad will hop? I have replaced engine in the car recently an the mechanic said the mounts were all good. Still dunno what cradle mounts are :(
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby postfach » Sun Aug 30, 2009 2:05 am
the cradle = the rear subframe
postfach
Postby avinesh » Sun Aug 30, 2009 4:03 pm
postfach wrote:the cradle = the rear subframe
sweet cheers for that man...
220.1 rwkw
jza80 supra = 11.7
avinesh
