Overheating corolla :(
Postby raddies » Wed Sep 02, 2009 12:18 pm
hey dudes
Bought a 1985 nana corolla to use as a dayly driver about 3 months ago.
Was a dream for the first month then developed this overheating problem. Whenever i drive it, even short distances, it seems to get to 3/4 hot on the temp gauge, sometimes even hotter.
It has a 1.5L carberated 3a series motor with the two radiator fans running fine. I did a compression test on her an it seemed ok" :?
It is using a little water though and am trying to think of ideas to the problem before I rip it apart an do a headgasket, which i cant really be stuffed doing.
Anyone know of anymore dead give away sign of a headgasket being shot? Or Could this be because of a really old crappy (inside) looking radiator etc?
Any help id be stoaked
Cheers, Nick
raddies
Postby Leon » Wed Sep 02, 2009 12:57 pm
I'd check for a blocked radiator, or stuck closed thermostat.
Postby MAGN1T » Wed Sep 02, 2009 1:22 pm
All toyotas blow headgaskets sooner or later. Your time looks like it's up now.
Radiators only block because the owners keep putting water in there. That's the effect, not the cause. Check for bubbles coming out while it's idling.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby ~SlideWays~ » Wed Sep 02, 2009 1:27 pm
MAGN1T wrote:All toyotas blow headgaskets sooner or later. Your time looks like it's up now.
Steve
Lol "all toyota's", thats a weird statement.
But anyway, I'd pull the radiator out and backflush it with a garden hose. Chuck it back in and see what happens.
Oh and as Leon suggested, take the Thermostat out and put it in boiling water to see if its actually opening.
~SlideWays~
Postby sergei » Wed Sep 02, 2009 1:54 pm
Steve
Load of crap.
Just like saying all mitsubishi blow head gasket sooner or later.
Postby sik_gt_starly » Wed Sep 02, 2009 2:43 pm
take oil cap off and see if the top of it is milky looking
if it is, will be blown headgasket
when its overheating, touch the radiator and see if you can feel cool spots
if you can its blocked radiator.
as mentioned take thermostat out and put in boiling water and seee if it opens.
those things should help you diagnose problem
sik_gt_starly
Postby Leon » Wed Sep 02, 2009 2:45 pm
The first poster specifically states the radiator is crappy looking inside. Not always an indicator that it is poked, but certainly it is not a good sign.
Postby Mr Revhead » Wed Sep 02, 2009 4:46 pm
Steve
yep, anything will blow a head gasket sooner or later
excpet maybe mitsi's as they will just blow up before the gaskets get old enough to blow :wink:
as has been mentioned, check radiator and thermostat before you do anything else. easy to check, and most likely your problem.
A series motors are not prone to blown gaskets, unless there's been other faults. ie lack of anti freeze, or old age, and lets face it, thay are all old with high kays now.
Postby raddies » Wed Sep 02, 2009 5:46 pm
hey guys
Thanks heaps for the help, i did replace the thermostat a month ago as thought it would be the issue but no good came of it. Checked to see if any air bubbles where appearing in the radiator while it was idoling the other day, no bubbles were apparent.
Ill take the rocker off tomorow to see if its milky
Also noticed that once its overheated, if i put it in neutral (dirty automatic corolla here) an rev the engine thus spinning the water pump it soon reduces to a normal temp, thinking this would illistrate there is no blockage as it must be flowing through radiator?
Thanks dudes
Nick
raddies
Postby Leon » Wed Sep 02, 2009 5:54 pm
raddies wrote:thinking this would illistrate there is no blockage as it must be flowing through radiator?
I wouldn't bet on that. It might be an indication that the radiator is flowing just enough to cool an unladen engine at idle.
I had a Starlet that you could do 50k in, but as soon as you went to 100 it just got hotter and hotter, then spat the coolant. It was indeed a mostly blocked radiator.
Postby raddies » Wed Sep 02, 2009 7:08 pm
Yeah good thinking Leon.
Maybe the radiator is slightly blocked thus only letting minimal flow through, thus when I rev the engine the flow it is increased an just sufficient to cool the engine, (which is occuring)
Checked uder oil cap looks fine..
Time to rip out the radiator an flush it out i reakon.
Nick
raddies
Postby Mr Revhead » Wed Sep 02, 2009 7:19 pm
it's also possible that the blades on the water pump have corroded away.
if the rad is full of rusty shit, and clearing it out doesn't solve it, checking the water pump would be a good idea
Postby 1hypo3 » Wed Sep 02, 2009 7:48 pm
Steve
Based on what experience? :roll: :roll: you have no idea mate :? 8O
1hypo3
Postby Loudtoy » Wed Sep 02, 2009 9:30 pm
1 Blocked radiator
2 Stuffed water pump
3 Combination of the above
4 Blown head gasket, but not so likely
My guess would be no 3
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Akane » Wed Sep 02, 2009 10:14 pm
+1 on blocked radiator, it happened as soon as I drained the coolant and started adding just water, touch the raid it's most probably be cold down the bottom.
Use a clean oil dipstick and shove it down one of the channels carefully, check again, then you might have a warmer channel down where you shoved the dipstick down, indicating a blocked radiator.
And it uses a bit of water because the water boils and then the rad cap will lift off with the steam, so it keeps on using bit of water every now and then.
Postby rollaholic » Thu Sep 03, 2009 1:25 pm
radiators do block up pretty easily when coolant mixture gets too weak. does it get hot when you are moving too? older radiators often lose alot of their fins, particularly around the fans which make them a bit average at cooling.
if you want to spend money on it, get the radiator checked by a specialist - cuts out all the guess work. (auto radiators in grey lynn are good if you are in the area) dont forget to do a solid flush on the engine before putting your shiny recon radiator back in too, all the stuff that built up to block it in the first place has come from corrosion in the engine block. if you dont want to spend money on it, you could hit up pickas or similar for a 'cross your fingers and hope it fixes it' solution.
PS putting a thermostat in boiling water is a good way to $&#$% it, they are designed to open at ~80 degrees and boiling water is closer to 100. even mostly screwed thermostats will often open at that temp. better to put it in cold water then heat it, it should be opening well before it boils.
DO use coolant half and half with water
DO replace the radiator cap
Postby MAGN1T » Thu Sep 03, 2009 2:37 pm
Steve
Based on over 30 years playing with cars and putting over 250,000 Ks on the same Toyota daily driver.
Most young guys got no idea......should have studied Chmistry and physics at school instead of only attending school in order to eat your lunch.
Any motor with an alloy head.......as soon as you start putting water into the cooling system, it's pretty much all over. Proper coolant only.
Steve
MAGN1T
Postby ~SlideWays~ » Thu Sep 03, 2009 2:51 pm
Steve
Steve
Where did the 'young people' thing stem from saying 'all toyotas' will blow headgaskets?
Just because you have experience, doesn't mean you can assume everything and make baiting comments all over the place.
~SlideWays~
Postby Mr Revhead » Thu Sep 03, 2009 6:48 pm
Steve
Steve
so in other words... based on nothing at all.
:roll:
If you don't know, don't post.
Postby rwd_mayhem » Thu Sep 03, 2009 8:43 pm
Mr Revhead wrote:it's also possible that the blades on the water pump have corroded away.
this exact thing happened to my old 3a, took me ages to figure it out too.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
