Bazda wrote:He does not use VVT as he has massive cams which dont cater for VVT.
If you have stock cams use the VVT to your advantage!
Bazda wrote:I did a back to back comparison with mine.
VVT def makes up alot down low.
Something like 30-40kw+ atw from 2000rpm-5000rpm. And also the same gain in torque.
AceSniper wrote:using vvt and aftermarket cams wont net the gains the cams were designed for as they are made for different timing to sdt.
