Here are the pics/diagrams of air lines on silvertop
By (A) and (B) in P/S IDLE/UP I mean first and second hose from valve on steering rack (the order does not matter)..
PURGE solenoid is that green/blue solenoid just under the throttle bodies (bolted on the bracket/pipe combination where is the fuel return goes)...
