Loudtoy wrote:Ok sweet so off at 6800, i had it set a little lower but will bump it up a little, not to worried about a constant cruise speed as i can just put a switch in there to turn it off for touring stages. More looking to get rid of the massive flat spot thats there at 4-4500 rpm, just want to have the ability to pull from 4k if i'm half a gear up up out a corner, not chucking it down one to get it moving then back up again 2 seconds later as it gets to the rev limit.
Wonder if anyone knows the lowest rpm level that a car with a standard computer turns vvt on at??
Affroman wrote:stock ST is 4400, on off like swich
ChaosAD wrote:Ill be doing some datalogging of a standard silvertop ecu soon and can send you the logs if you want them. I've heard the rpm switch point depends on the tps angle.
BT varies from temp and load
est on comp is
.010 tho + .3 from 10.5 = 10.8
.020tho + .5 from 10.5 = 11
.030tho + .8 from 10.5 = 11.3
.040tho + 1 from 10.5 = 11.5
