2jzgte altezza
2jzgte altezza
Postby djb219 » Sat Sep 05, 2009 1:53 am
Am wanting a 2jzgte and r154 box to do this conversion so anyone with anything of help or any info let me know.
djb219
Postby tsoob » Sat Sep 05, 2009 10:38 am
cool!!!!!!!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby GTTpower » Sat Sep 05, 2009 11:05 am
What kind of altezza do you have? Easiest conversion Ive seen is in a AS300 Gita, as they came factory 2JZ, but could probably swap the JZ mounts over to an RS200.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby evil_si » Sat Sep 05, 2009 11:25 am
the gita mounts fit so engine will bolt in,
the cross members are different,
not sure if the gita c/m will bolt in, there were none available when we did the conversion, so i modified the stock member
a rear sump may be different and clear ok, we used a front sump
dont know about r154 as we used remote w58 and just made a mount to suit, had to fit captive nuts into chassis thou, the holes were there but 'blank'
evil_si
Postby djb219 » Sat Sep 05, 2009 11:41 am
I've got the IS200, the reason i need to do the conversion! Is the w series box still holding together?, i only thort r154 as they're stronger. Yea will use a front sump as have been told rears need alot of modificaion. If anyone knows anyone in Christchurch let me know.
djb219
Postby evil_si » Sat Sep 05, 2009 11:45 am
the car hasnt had to much punishment, 300wkw on 9psi, but the crank failed. so its been off the road most of this year, hopefully for not to much longer
the gearbox was always a bit noisy and seems ok, planning to strip and rebuild at some stage,
standard diff is still in there,
evil_si
Postby djb219 » Sat Sep 05, 2009 11:56 am
wow, thought the standard diff would be the first to blow! With the wiring did you manage to get everything working? And is a VVT-i engine any harder than one without?
djb219
Postby evil_si » Sat Sep 05, 2009 12:26 pm
adam had lots of issues with the wiring,
one of the biggest issues was the wanker the did a lot of it, basically he didnt know what he was doing and took a lot of shortcuts that cost us big. mite be why he now works at harvey normam
its running a link to control the engine,
the stock computer talks to the dash so that also has to be retained, (we found out after we had sold it with engine and loom) and the correct computer must be used or the dash wont work
the tacho and fuel guages are giving him issues
we have a supra diff waiting for the day the standard diff fails,
not sure with the vvti engine, the one we have is non vvti,
from my understanding the new link ecus will control it no problems
evil_si
Postby 88gtz » Sat Sep 05, 2009 6:21 pm
My altezza has a vvt-i 1JZGTE in it with a W58 and its held up fine to the punishment
88gtz
Postby ryanfels » Sat Sep 05, 2009 7:24 pm
88gtz wrote:My altezza has a vvt-i 1JZGTE in it with a W58 and its held up fine to the punishment
Brendons old 1?
ryanfels
Postby 88gtz » Sat Sep 05, 2009 7:38 pm
Brendons old 1?
Yeah it is
88gtz
Postby djb219 » Mon Sep 07, 2009 10:03 pm
ok cool. OK if anyone knows what would be an average price to pay for a r154 box inc everything for manual conversion, ie pedals cylinders etc?
djb219
Postby Alehandro » Mon Sep 07, 2009 10:23 pm
usually 1500-2000
Alehandro
Postby strx7 » Mon Sep 07, 2009 10:30 pm
djb219 wrote:ok cool. OK if anyone knows what would be an average price to pay for a r154 box inc everything for manual conversion, ie pedals cylinders etc?
a remote shift R154 box with manual conversion bits......... dont expect change from $3K probably closer to 3.5K
Postby YeMs » Tue Sep 08, 2009 1:28 pm
Alehandro wrote:usually 1500-2000
hmmm not in new zealand. however i know ewan can import r154 boxes for quite cheap.
i paid 3k for mine. box with a new puck clutch start motor flywheel etc.
Your local Hybrid Elite tech
YeMs
Postby djb219 » Tue Sep 08, 2009 4:02 pm
Also really need to sell my 1g-fe and auto box so let me know if anyone knows anyone
djb219
Postby djb219 » Wed Sep 09, 2009 8:52 pm
does anyone know of any cheap transport companies, need to get the gearbox etc from Tauranga to Nelson
djb219
Postby d1 mule » Wed Sep 09, 2009 9:58 pm
dont pay 3k+ for a gearbox man, look around, falsgraves in chch had a 2jzgte and V130 with pedals and loom for $3500 like a year ago hunt around
d1 mule
Postby djb219 » Wed Sep 09, 2009 10:09 pm
jeez thats cheap, if i can find a deal like that i will be the happiest man around!
djb219
Postby Mr.Phreak » Wed Sep 09, 2009 10:11 pm
V130??
Mr.Phreak
