I dont know that shortening the strut will help. the shock is already working in the upper part of range at the current ride height.
roytarolla wrote:300lb sounds like a good rate to try then. The current springs are 250mm free height. I know there completely wrong for this setup. But work well with the full length shocks especially on gravel.
I might give a pair of 300lb springs a go see what happens.
I normally make it to Dunedin every couple of months.
