BT smoking @ high rpm
Postby Dopamean » Mon Sep 07, 2009 6:56 pm
20v blacktop just started to do this around 5700 - 6k mark.
Does not use oil or that I can notice.
I've seen this before on cheaper fuel e.g. 91.
Haven't seen it before using 98+.
Am I being ripped off on my fuel?
I bought from BP last time I filled my tank and have heard a couple of stories about 91 being sold as premium.
I'll have to fill up back at mobile but it there anything common to wear to cause smoking only when hitting this rpm?
Dopamean
Postby Mr Revhead » Mon Sep 07, 2009 7:23 pm
what colour smoke?
check it from outside the car as easy to be mistaken when looking in the mirror
Postby Dopamean » Tue Sep 08, 2009 8:18 pm
Looks grey,
May be its early signs of a leak in the head gasket.
more $$$ :roll:
Dopamean
Postby AceSniper » Tue Sep 08, 2009 8:47 pm
doubt its the h/g unless its been overheated
would think rings
AceSniper
Postby tomtom » Tue Sep 08, 2009 8:52 pm
yea my 20v did that exact thing..was rings...nt good
TRUENO gtz! AND 1UZ MANUAL SOARER!
tomtom
Postby deaf_rattle » Wed Sep 09, 2009 7:03 pm
i thought 20vs came from the factory with smokey exhausts? :wink:
Postby Dopamean » Wed Sep 09, 2009 7:58 pm
Strange seems intermittent, wonder if it’s just the "blowing the crap out the back" although this is hopeful thinking :/
Not trying to be an idiot revving the crap out of it but just trying to reproduce the problem.
Normally this is the equivalent of an engine rebuild?
Dopamean
Postby Mr Revhead » Wed Sep 09, 2009 9:28 pm
is it blowing huge clouds?
is it using HEAPS of oil?
has it lost masses of power?
if no to all of those, just keep driving and stop worrying
Postby Bling » Wed Sep 09, 2009 11:06 pm
deaf_rattle wrote:i thought 20vs came from the factory with smokey exhausts? :wink:
Thats what I thought 2 :lol:
Mr Revhead wrote:is it blowing huge clouds? Yes
is it using HEAPS of oil? Yes
has it lost masses of power? No
This is for mine, its done it since the day it got imported (coming up 5 years), slack jap owner not servicing it. My opinion of heaps of oil would be a 4L used between services usually around the 5k mark :lol:
Postby MAGN1T » Wed Sep 09, 2009 11:24 pm
Checking the plugs is always a good start.
As in look at them carefully, make sure they're all the same.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Mr Revhead » Wed Sep 09, 2009 11:25 pm
:? hell that's a lot
why do you even both with oil change? just change the filter every 3 months :lol:
Postby Bling » Wed Sep 09, 2009 11:50 pm
Yeah I wonder that myself sometimes :lol: Its also the reason I haven't dared take the cam cover off.
Postby Dopamean » Thu Sep 10, 2009 10:20 am
MAGN1T wrote:Checking the plugs is always a good start.
Steve
Plugs are probably the only untouched thing on the car and I have not checked them, probably even due for replacement.
Can someone tell me what the correct spacing is on the plugs for a blacktop?
Checked the oil again today - no change since I first noticed the smoke.
No discoloration in the oil either.
No water loss.
No Smoking when punching it either, wonder if it was a bit of "crap" burning out in the exhaust system?
I've owned some mitzys in my time and one in particular I can equate to a bazoka smoke machine, worthy of replacing a smoke machine on a rockstar stage.
No it was not bellowing smoke but close, again did not do it in the normal rpm range 1-4k but 5+.
The only time I've seen this is when using 95 octane or below.
I had put in 98 so it concerned me but self admitted I'm a car hypochondriac.
I think Rev is right, no further signs (so far) so forget about it.
It will bring my blood pressure down too :roll:
Dopamean
Postby Crampy » Thu Sep 10, 2009 10:58 am
Steve
Should have a 1.1mm gap.
Crampy
