Venting w/g externally
Postby cat007 » Wed Sep 09, 2009 2:01 pm
Hey all
I currently have my external venting to the atmosphere as I LOVE the sound of it, mainly because its not some pokey 4 pot ;)
But anyway, I’m going to be getting a cert for the car, AGAIN, and of course venting externally isn’t ‘legal’.
Other than running a piece of pipe all the way to the rear of the can so I can still have that sound – what other solutions have I got? I only have a 2.5” exhaust – so unsure if plumbing it back in will work for the power output the engine will be making (+400hp)?
How far back would the pipe have to run for it to be legal? Last opening door, or window isn’t it? So the boot doesn’t count? So in theory it could go back to just in front of the rear wheels?
And please don’t give me shit about having it venting externally. I like having 2 different exhausts tones depending on how much I’m leaning on the engine…
Cheers :)
Hunt
Postby gasman » Wed Sep 09, 2009 2:13 pm
plumb it back in but make it removable so that after cert and wof time u can bolt your screemer back on. at least thats what i did.
try and plumb it back down the exhaust as far as possible away from the turbo.
on my car there is a noticable difference in power with it plumbed back vs vented.
"What can possibly go wrong?"
gasman
Postby tsoob » Wed Sep 09, 2009 2:26 pm
gasman wrote:plumb it back in but make it removable so that after cert and wof time u can bolt your screemer back on. at least thats what i did.
what he said!!
yeah youll find the cert/wof guys are pretty clued up on this type of setup now and even some of the police 2 so be carefull.
oh and just for fun chuck a screamer on it eoh
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby cat007 » Wed Sep 09, 2009 2:28 pm
what he said!!
yeah youll find the cert/wof guys are pretty clued up on this type of setup now and even some of the pigs 2 so be carefull.
I thought a "screamer" was just the fact that the wastegate vented externally?
Would there be any restriction/performance issues with having the external plumbed all the way back (following the main exhaust) and venting after the last opening....?
Postby bluemaumau » Wed Sep 09, 2009 3:05 pm
what he said!!
surely if you have it plumbed in tho it doesnt matter
they cant fail you becuase theres a few flanges on the wastegate pipe
Postby cat007 » Wed Sep 09, 2009 3:30 pm
bluemaumau wrote:surely if you have it plumbed in tho it doesnt matter
Yeah you might be onto something - I guess I'll have it plumbed in and then maybe make up some sort of bypass system for later....
Postby mjrstar » Wed Sep 09, 2009 3:44 pm
My car made 245kw with the external plumbed back in on the 2.5'' crush bent pipe.. sure it made 15kw more the rear section of the exhaust unbolted, but that's another story..
As for venting to atmo personally i do not like the idea unless you have a dedicated drag car... but my mates evo 5 had a decent setup which basically meant he could have it either plumbed back or atmo by inserting a blanking plate and removing a connecting pipe. it was about 8'' long and flanged at both ends and ran from the w/g bak to the exhaust.. was about 15min to remove/refit.
when i got my evo4 it has a certified exhaust (under 95db) and it had a external venting w/g with a blanking plate.. this is not ideal as the car basically has the ability to freeboost.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby cat007 » Wed Sep 09, 2009 3:59 pm
mjrstar wrote:My car made 245kw with the external plumbed back in on the 2.5'' crush bent pipe.. sure it made 15kw more the rear section of the exhaust unbolted, but that's another story..
Surely thought just having the w/g blanked off the LVVT guys would know what's what and would say something about it?
Postby mjrstar » Wed Sep 09, 2009 4:51 pm
i would have thought so too, but i have the paperwork.. i guess with it blocked off it is 'legal' but as soon as you take the blanking plate off you no-longer comply with the paperwork. it states 'blanking plate on external w/gate' i'm pretty sure.
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby cat007 » Wed Sep 09, 2009 4:57 pm
mjrstar wrote:i would have thought so too, but i have the paperwork.. i guess with it blocked off it is 'legal' but as soon as you take the blanking plate off you no-longer comply with the paperwork. it states 'blanking plate on external w/gate' i'm pretty sure.
Well I'll get it plumbed in for now - then have a chat with the LVVT guys and see what's what.
I really need a new exhaust anyway - well at least a new rear muffler as mines pretty old and I would imagine restrictive lol
Postby deaf_rattle » Wed Sep 09, 2009 7:02 pm
vented sounds like ass.
just plumb it in.
Postby Boosted_162 » Wed Sep 09, 2009 7:06 pm
I have my external with a screamer, then i have a bolt in section to join into the exhaust. Definately the best idea IMO. And if they ask about the flanges, just say they are required as for installation. If mine was welded in, it would be impossible to remove unless the whole motor comes out.
Postby iOnic » Wed Sep 09, 2009 7:20 pm
Nothing illegal about having an atmo venting WG on an MR2 - it exits behind the rearmost opening door ;)
Having a flange in it isn't legal but most WOF guys won't pick up on it. You're not allowed to have any removable components that alter your exhaust noise (bolt in silencers etc)
Postby fangsport » Wed Sep 09, 2009 7:30 pm
Cat 007, i suspect you do a wee bit of trackwork, therefore, build the highest performance plumb-back or separate WG exhaust. it would be a rude feeling, knowing you were fastest on the day, only to be excluded for a non-compliant car , aye.
Cert guys/ cops etc may not notice, but MSNZ tech guys are usually on the case :wink:
fangsport
Postby drftdr » Wed Sep 09, 2009 8:55 pm
Im venting my wastegate to just in front of the passengers rear tyre.
On a 180sx, with no rear seats due to half cage.
As said above you could have a blanked of flange so can vent or flow back into the exhaust.
This is on a Rb25det by the way
Drftdr
drftdr
Postby cat007 » Wed Sep 09, 2009 9:37 pm
fangsport wrote:Cat 007, i suspect you do a wee bit of trackwork, therefore, build the highest performance plumb-back or separate WG exhaust. it would be a rude feeling, knowing you were fastest on the day, only to be excluded for a non-compliant car , aye.
Yeah - I totally see where you're coming from, and you're right. Its not worth the risk really....
When you say a seperate exhaust - would it need to be silenced/muffled?
I would like to run a seperate 1-1.5" pipe from the wastegate right to the back, and next to the main muffler - like on the Ferrari F40 :)
But I guess I'll talk to the LVVT guys and see what they say.
Postby tsoob » Wed Sep 09, 2009 9:47 pm
Boosted_162 wrote:I have my external with a screamer, then i have a bolt in section to join into the exhaust. Definately the best idea IMO. And if they ask about the flanges, just say they are required as for installation. If mine was welded in, it would be impossible to remove unless the whole motor comes out.
i hear that a pretty mean set up 2 :wink:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Boosted_162 » Wed Sep 09, 2009 9:49 pm
Got a mean downpipe too :wink: :wink:
Just need a new motor now :(
Postby IH8TEC » Wed Sep 09, 2009 10:48 pm
just plumb it in, i didn't think i'd like mine at first, but the car sounds soooooo much crisper with the external plumbed in. i think it reflects the sound of a racecar better.
it took me a while to get used to because if i heard the screamer i knew the boost controller was working haha. now i just trust it. i had to get it plumbed in for my cert also.
Postby slammed_integral » Wed Sep 09, 2009 10:57 pm
sounds awesome and if you dont think so your too pc
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
