I'm picking up a new ute this weekend but I know it has a couple of things I need to sort out. first item is the chassis rails have a light coating of surface rust , and is just starting to flake . Its been on a hoist and its appears to be just on the surface, I'm guessing its from rocks and gravel etc so I just need to clean it up well enough to get a couple of years out of it.
here what I had in mind, please correct/confirm if I'm on the right track.
-strip affected areas with wire wheel, clean and sand
-coat rails in POR15 rust preventive paint
-coat rails in POR15 chassiscote
have I missed anything?
