Lazy GTZ... (NOW FOR SALE)
Postby V-JAY » Fri Sep 11, 2009 2:03 pm
Hey guy's wondering if I can pick anyone's brains here?!
Recently picked up a '91' AE101 GTZ Levin. I've done heaps and heaps of searching since I joined and found some really helpful info so cheers.
In short...
1.) She idle's like a pig when started from dead cold with rich smelling emissions from the exhaust until warm!
2.) Supercharger doesn't really seem to superly-charge anything? Have topped up with genuine Toyota oil.
3.) Open road driving causes temp to drop very low, however fans still kick in once she gets up to temp when stationery.
Any help would be great!
P.S. If anyone needs bearings, I'm your man.
Cheers.
V-JAY
Postby FLAWLES » Fri Sep 11, 2009 2:25 pm
temp issue is a commin thing on them, mine done it but not that bad, open road driving it would below 1/4 then when still it would be half way
just one of those things
what size s/c pulley do you have? make sure the belt is tight, they are prone to slipping
idle, i remember mine had something to do with the cold start injector, but this is going back yrs ago and i cant remember weather or not this is true
FLAWLES
Postby V-JAY » Fri Sep 11, 2009 3:04 pm
Cheers dude, yeah from what I've read here already the GZE is notorious for idle/temp issues.
S/C pulley is bog standard, the whole car has literally never been played with which is kind of good I suppose.
Any way I can tell if the cold start injector and or sensor is rooted?
V-JAY
Postby sergei » Fri Sep 11, 2009 3:07 pm
Temperature thing is the stuck thermostat (located in the housing on the gearbox) 15min job (~$30 genuine?).
When cold does it sound like miss? Have you checked leads/plugs?
Postby V-JAY » Fri Sep 11, 2009 3:13 pm
sergei wrote:Temperature thing is the stuck thermostat (located in the housing on the gearbox) 15min job (~$30 genuine?).
Choice, thanks mate. I'll rip the thermostat out and replace that first. Definitely sounds like it has a slight miss when started from cold, idles stupidly low untill you give it some gas. Haven't been down the plug and lead road yet coz it seems like it's running far too rich?!
V-JAY
Postby sergei » Fri Sep 11, 2009 4:53 pm
They have cold start injector, that is operated by a thermo-swtich (brown plug located on coolant elbow, gearbox side, although I could be mistaken on location). Sometimes that thermo-switch does not work properly that could cause the issue you describe.
Postby KwS » Sat Sep 12, 2009 12:53 pm
the temp issue will definately be thermostat. Just changed the one on my silvertop for that exact issue.
Very easy, and yes it cost about $30 for genuine parts. Just make sure you get a new rubber o-ring too. Youll loose about 1-2L of coolant unless youre ninja quick.
KwS
Postby Mr Revhead » Sat Sep 12, 2009 12:55 pm
idle wil lprob be the ISC (idle speed controller) always crap out on these. sometimes cleaning them will help. but I have yet to come across anyone who has fixed one
Postby jakesae101 » Sat Sep 12, 2009 1:16 pm
i have none of those issues hower my gtz first start of the morning or sometimes after work it takes a bit of cranking to get it to start has improved quite a bit since new plugs but still the issue is there
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby V-JAY » Sat Sep 12, 2009 5:46 pm
Really appreciate the feedback guys....
Bit of an update.... replaced the thermostat on Friday night, didn't alter the idle speed at all, however operating temperature is now steady even with open road driving so that's one thing ticked off the list!
Now, we adjusted some strange looking white coloured plastic box right on top of the inlet manifold (excuse my ignorance), we loosened the two screws either side and virtually turned it anti-clockwise as far as it could go before hitting the casting and re-tightened the screws, idle is 10 times better.. dropped from 1500Rpm to around 950Rpm.
Revhead: Would this have been the ISC? Didn't look like it would come off easily without damaging the metal retainers holding it at the bottom?!
Sergei: Have read a lot of info on here about the cold start injector, where exactly is it and what do I try and replace? Injector or thermo switch?
P.S. Sorry if anyone has fallen asleep! :lol:
V-JAY
Postby Mr Revhead » Sat Sep 12, 2009 7:05 pm
yes thats it.
you have to pry the retainers off apart to remove it. i wouldn't bother with that if you have made it better by adjusting it
Postby V-JAY » Sun Sep 13, 2009 12:11 pm
Yeah didn't look like it would come off easily, knowing my luck I'd butcher it for sure! :x
So has anyone replaced the thermo switch on these? Is it ok to replace with a second hand unit?
V-JAY
Postby sergei » Mon Sep 14, 2009 9:35 am
http://www.toyodiy.com/parts/p_J_1992_TOYOTA_LVN_AE101-ACMXR_8404.html
Part number: 89462-20030 is the cold start injector switch.
You can replace it with second hand, provided if it works, there is a way to check it (no need to replace things blindly).
Postby V-JAY » Mon Sep 14, 2009 10:21 am
Cheers sergei, please do explain on how I check this?
V-JAY
Postby sergei » Mon Sep 14, 2009 10:53 am
V-JAY wrote:Cheers sergei, please do explain on how I check this?
Measure voltage at the cold start injector, it should only fire when car is cold (overnight cold) and cranking.
I will let you know exact processes when I get home and look at the manual (3SGTE in this case, but same principle).
Postby sergei » Mon Sep 14, 2009 11:01 am
Here, with some googling and shamless stealing off here:
http://yotatech.com/f116/cold-start-inj ... re-157372/
Postby sergei » Mon Sep 14, 2009 11:33 am
http://autoshop101.com/forms/h22.pdf
More info there, scroll down to page 20.
You also could check by simply disconnecting it, and see if it still smokes on start up.
Postby mr30%jr » Mon Sep 14, 2009 11:35 am
firstly: warm the car up.
turn car off and take battery lead off for like a minute.
put lead back on and jump in and go for a 5min hoon just free rev the car and get up to at least 100km if you can.
come back and turn the car off... open the diag plug behind the battery and short E1 and T1
turn the key onto ON but dont start.
if you get anything other than continuous steady blinking let us know.
mr30%jr
Postby themaleman » Mon Sep 14, 2009 1:46 pm
i have my cold start injector unpluged all the time. car still starts mint
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Quirky » Mon Sep 14, 2009 2:52 pm
My GZE has all these symptons :(
Good to know its a common problem.
As for starting in the morning, i just rev it slightly to get it to idle, been doing this for nearly a year...
Hello There
Quirky
