3s - t50 clutch?
3s - t50 clutch?
Postby Infinite » Fri Sep 11, 2009 10:38 pm
Will a clutch flywheel and pressure plate from a gen 1/2 mr2 fit onto a st162 motor and t50???? just i happend to split the box off a old mr2 i had and it happens to have a nice flywheel and hd excedy clutch!
Lots
Infinite
Postby KinLoud » Sat Sep 12, 2009 8:43 am
It should fit if it is a N/A flywheel. I presume you know about milling bellhousing or spacing release bearing carrier and clutch fork to make it work?
May not be enough room if it is the turbo setup
Ken
Postby mr30%jr » Sat Sep 12, 2009 9:03 am
no they dont last time i sloted the 3sge clutch on a t50 22spine it was too big
mr30%jr
Postby Infinite » Sat Sep 12, 2009 9:04 am
sweet yea its na... it was setup in the car befor i got it? guys done 8 years of burn outs on it so seems to work well lol
Lots
Infinite
Postby Infinite » Sat Sep 12, 2009 9:19 am
aw dam...
Lots
Infinite
