PLX-KIWI fuel economy meter
Postby KinLoud » Sat Sep 12, 2009 7:31 pm
US company makes fuel economy computer.
http://www.plxkiwi.com/
Ken
Auck
021 408 863
Postby Akane » Sat Sep 12, 2009 10:15 pm
Not bad, quite affordable. but probably made in China inside anyway :P
Postby sergei » Sat Sep 12, 2009 10:49 pm
Yeah, and there is no list of cars it works with.
I doubt it works with non OBD cars (like my 1998 GT4).
All they say works with 1996+ vehicles, which a bit broad, kind of false advertisement.
Postby Infinite » Sat Sep 12, 2009 11:19 pm
Installation:
The Kiwi connects to any 1996 and up vehicle through the OBDII port often located under your steering column.
Lots
Infinite
Postby Alex B » Sat Sep 12, 2009 11:49 pm
Isnt it regulation in USA that all post 96 cars are OBD2?
Postby Infinite » Sun Sep 13, 2009 1:57 am
wouldnt it be classed as driver distraction? Constantly watching it to make sure your driving to its requirements.... $&#$% that shit. itd be like owning a cellphone but not using txt... if u cant afford to run it u cant afford to own it. /end rant
Lots
Infinite
Postby Mr Revhead » Sun Sep 13, 2009 11:40 am
Alex B wrote:Isnt it regulation in USA that all post 96 cars are OBD2?
yep, something like that
Postby MAGN1T » Sun Sep 13, 2009 11:13 pm
Only in america......not in japan until a bit later.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby cat007 » Sun Sep 13, 2009 11:33 pm
Is this some kind of joke?
It has to be right?
Postby Adoom » Mon Sep 14, 2009 8:04 pm
cat007 wrote:Is this some kind of joke?
It has to be right?
What do you mean?
Its not one of those magic magnets that make your car use less gas....somehow.
Its basically just a measuring tool that teaches you to keep your foot off the gas.
Adoom
Postby sergei » Mon Sep 14, 2009 8:49 pm
It just takes data off the OBDII connector (airflow, duty cycle etc), and calculates MPG.
Will not work with most of japanese performance cars until the era of Altezzas and such.
Postby sergei » Mon Sep 14, 2009 8:58 pm
Those MPG meter are gimmic anyway, as it will display current fuel consumption which is not true in long term. Also long term avg. is useless, due to nature that it has been done, and you don't know what you were doing wrong.
As I stated many times before the most economical acceleration will be near full throttle, that thing will show consumption going through the roof during "burn" period, and mislead the driver.
To properly measure economy, you will need to output engine efficiency on the display, not current "miles per gallon" or km/l. Efficiency of the engine is very engine specific so you cannot make a generic cheap gadget.
By Efficiency I mean energy conversion efficiency (power extracted from a quantity of fuel) and not volumetric efficiency.
Postby MAGN1T » Tue Sep 15, 2009 12:30 am
Vacuum gauges used to be popular. They do the same job.
Steve
MAGN1T
Postby frost » Tue Sep 15, 2009 12:57 am
my bimmer has this feature, its quite accurate within about 6-8km from full to empty 80ltr. tells current usage rate and liters per 100klm. and expected coverage.
really useful to remind me to stop lead footing. but being a lazy v8 its not hard to want to stomp on it.
also has a power bar?! still not sure what its for but its like how much more power is available if i put my foot down.(i think)
