altezza oil leak
altezza oil leak
Postby tech128 » Sun Sep 13, 2009 8:45 pm
i was doing a service on the altezza when i noticed that the right hand
inner guard area is covered in engine oil so i traced it to the air box and filter and it was nearly full
of oil
i can only think of this being a pcv hose fault or some times happends when over full which is happened to me on another car b4
after purchasing
any ideas /common things car has done 170k
2l beams auto
tech128
Postby Mr Revhead » Sun Sep 13, 2009 11:18 pm
could be gunked up head slowing oil from draining from the head and instead blowing out the cam cover vent hose.
or shagged rings pressurizing the crank case, with similar effect.
Postby ROBODISCO_20v » Tue Sep 15, 2009 5:45 pm
It's pretty normal for them to have a little bit of oil in the intake pipe but yours sounds really bad. Have you checked the PCV? There 6-8 cap screws holding the engine/cambelt cover on so it's pretty easy to get to once you get that off (amusing you have the 4cyl 3SGE).
ROBODISCO_20v
Postby MAGN1T » Tue Sep 15, 2009 9:07 pm
Most oil leaks are caused by the crankcase presure being too high.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
