enlargering rear speaker holes cert?
Postby Infinite » Mon Sep 14, 2009 6:29 pm
My car at some point has had 6x9's in it and the cock sucker cut the wholes to accomidate this. And ive finialy been pulled up on a wof with it... what is the normal procedure for fixing this? tidy the cut? low volume cert it?
Lots
Infinite
Postby frost » Mon Sep 14, 2009 6:42 pm
same happened to me, you need a engineers report, take it to a body shop and get them to weld a plate to replace what was cut out but dont paint it till the engineer has seen the work. he will give you a paper saying the repair was done correctly,
depending on how much was cut out the engineer might just say its ok and clean up the edges,
Postby Infinite » Mon Sep 14, 2009 6:54 pm
sweet $&#$% all is out but its rangi! then they have bent parts of it down... thanks for the info will be off to panel beater tomorrow!
Lots
Infinite
Re: enlargering rear speaker holes cert?
Postby Adoom » Mon Sep 14, 2009 8:10 pm
Infinite wrote:My car at some point has had 6x9's in it and the cock sucker cut the wholes to accomidate this. And ive finialy been pulled up on a wof with it... what is the normal procedure for fixing this? tidy the cut? low volume cert it?
LOW VOLUME CERT IT!??!!!!!
Unless your wof guy is a prick, he should just let you get away with it if you weld a plate over the hole.
IMO, engineer's reports are for when you replace/repair major structural parts of the car.
Adoom
Postby sergei » Mon Sep 14, 2009 8:44 pm
As far as I understand, you don't even need engineers report, the car is not getting (re)complied.
Postby mjrstar » Mon Sep 14, 2009 9:39 pm
I think I recall something to do with 'closer than 300mm from a seatbelt anchorage' when my mate got pulled up on his WOF.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Lloyd » Mon Sep 14, 2009 10:42 pm
Yeah, its only if its within 300mm of a seatbelt anchorage or if the AVI has decided its a structural part of the car. Just clean up the edges and weld a plate over it to give it back any strength that may have been taken out of it and go back for a recheck. Inspectors are getting pretty picky if they want a cert/report to say its good. If you get asked for that then I'd be findind somewhere else for warrants
Postby frost » Tue Sep 15, 2009 12:20 am
i got pulled up on it and had a note placed on the wof sheet saying it had been repaired correctly,
it was considered a structural part when i had the car re-vin so that's where the engineers report was needed, im sure its still needed as almost all modern cars rear trays are important structural area,
bloody Muppets and 6'9' when will they learn...
Postby Infinite » Tue Sep 15, 2009 9:30 am
ok ill ring arround would love for it to be 300mm of seat belt mounts.. but yea 6'9 muppets suck!
Lots
Infinite
Postby Paulio » Tue Sep 15, 2009 9:33 am
The easiest way is to get a report from a certified engineer to say that even though they are cut, the structural integrity is still good. Mine are cut and I paid $20 for one of these and havnt had a problem since.
yees booy
Paulio
Postby Infinite » Tue Sep 15, 2009 1:23 pm
well by the looks of it, its the 300mm away from a seat belt anchor means the wof man has to stfu and deal with it.
Lots
Infinite
Postby 2LTR Rona » Tue Sep 15, 2009 3:24 pm
has this same issue in my AE101, was noted and failed on WoF, we welded a section back in to get it as close to factory as we could, treated and primed, flew through recheck.
re : means the wof man has to stfu and deal with it
reality is now that its noted, untill he / she is happy it wont pass
best thing to do, plate, weld & be done with it
2002 Altezza, 1974 KE25
2LTR Rona
Postby Infinite » Tue Sep 15, 2009 7:34 pm
wont be geting plated and welded if a certifier says its fine.
Lots
Infinite
Postby Lloyd » Tue Sep 15, 2009 11:55 pm
Its not up to a certifier, its up to the inspector
Postby Bling » Wed Sep 16, 2009 12:14 am
Is it really getting so worked up about a parcel shelf?? :?
Weld it up and move on with life imo :lol:
Postby celica_xr9145 » Wed Sep 16, 2009 12:39 am
so what about the parcel shelf on my celica st183?
The parcel shelf lifts up with the boot and where the 6x9's are placed, there isnt any metal and i cant see how its a structural part as it basically sits onto the plastic trim :?
Is that legal? :?
celica_xr9145
Postby Alex B » Wed Sep 16, 2009 12:46 am
Correct, cardboard with carpet is not structural.
Postby Paulio » Wed Sep 16, 2009 9:48 am
I booked my car in to get the parcel shelf speaker holes welded back to factory by a certified engineer and instead of doing the work he said that the damage it is only minor and he could certify that it was still structurally sounds & safe.
If it aint broken dont fix it.
Of course if its major then it has to be fixed. WOF guys are pretty heavy on the structural stuff like this, as they should be.
yees booy
Paulio
Postby 1I1 » Wed Sep 16, 2009 2:28 pm
celica_xr9145 wrote:so what about the parcel shelf on my celica st183?
Is that legal? :?
The thing you need to look at is does it contribute to strength of the body or seat belt mounts? Both of which are no so you can cut it up remove it etc and it will be fine.
Paulio wrote:Of course if its major then it has to be fixed. WOF guys are pretty heavy on the structural stuff like this, as they should be.
Exactly. If they pass your car with a cut up parcel tray to allow 6x9's etc to fit within 300mm of the seat belt anchorage, you and your mates go out and crash just after a wof the seatbelt and surrounding metal tears from the force of a 80kg passenger suddenly going forward who does it fall back on?
TRD Clicky >>Here
1I1
Postby Paulio » Wed Sep 16, 2009 5:16 pm
Yeah yeah im not a bogan all im saying is that mine were cut but it didnt affect anything, so they didnt need to be welded up. My seat belts are anchored in to the pillar safe and sound.
I say curse manufacturers that anchor the seat belts to the parcel shelf structure.
Infact, curse the mungrels that murder parcel shelfs!
yees booy
Paulio
