oopsie on the caliper bolt
Postby flygt4 » Fri Sep 18, 2009 6:26 pm
so during a nice simple change of the rear brake pads to get a WOF on the caldina, I have managed to shear the bottom caliper slide bolt in the caliper
:x
there is only about 5mm showing from the caliper, and its stuck tight.
I am thinking something like an easy out and then I'll need to redrill it and tap or helicoil a thread in it.
any suggestions for the easiest way to sort this?
flygt4
Postby evil_si » Fri Sep 18, 2009 6:45 pm
if its protruding, or sticking out the best way imo is to weld a nut over top, the heat is usually enough to free it and it will unwind easily
evil_si
Postby flygt4 » Fri Sep 18, 2009 6:54 pm
evil_si wrote:if its protruding, or sticking out the best way imo is to weld a nut over top, the heat is usually enough to free it and it will unwind easily
yeah its borderline if its enuf to weld to without welding to the caliper too. might be worth a shot though
flygt4
Postby AceSniper » Fri Sep 18, 2009 7:09 pm
2nd welding, could also build it up with weld before welding the nut on
AceSniper
Postby d1 mule » Fri Sep 18, 2009 7:59 pm
easy outs suck man, dont bother, def weld a nut on
d1 mule
Postby ~SlideWays~ » Fri Sep 18, 2009 8:03 pm
I did the same except had rounded the head because it was seized. I ended up putting a much bigger nut onto the rounded head, but I welded inside the big nut. That way your less likely to weld something other than the bolt.
~SlideWays~
Postby neo » Fri Sep 18, 2009 10:04 pm
I have brake line clamps, clamp off the line, take off the caliper and bring it over - have big vice and welder :)
neo
