MAGN1T wrote:Doing it the way in the photo disables the PCV system. So now there's no fresh air being drawn through the crankcase.
So it's a downgrade as in a step backwards as in screwing up the motor.
It depends on why you're fitting it. If you actually need one, then your motor is already screwed and so it's just a bandaid.
Steve
Mr Revhead wrote:I ran my ae101 like crampys set up.
some times you get a whiff of the oil fumes, other than that there is no disadvantage. the big advantage is it stops the fumes getting into the intake, and is a big help in reducing the pinking and stuttering these things get at times.
Steve
Crampy wrote:Mr Revhead wrote:I ran my ae101 like crampys set up.
That's not actually my setup. I found it on the net, but I'll be doing the same sort of thing.
Short of putting a vacuum pump on it, I'd say this is the best way to do it on the 20V.
Mr Revhead wrote:prob best to resell the one you have and get another
deaf_rattle wrote:Crampy wrote:Mr Revhead wrote:I ran my ae101 like crampys set up.
pretty sure thats how the silvertop one is set up in the fxgt of doom.
and there is abit of oil in that catch can.
