4AGE piston rings - ridge?
Postby Vertigo » Sun Sep 20, 2009 2:48 pm
im fitting some new piston rings, and ive noticed that they have a sort of ridge on one side, suggesting that they go in one way. any ideas?
TVIS just kicked in, yo!
Vertigo
Postby Lloyd » Sun Sep 20, 2009 5:39 pm
Put it to the top side. Should have had instructions that came with the rings
Postby Vertigo » Sun Sep 20, 2009 9:59 pm
sadly not. cant find anything on the net about it. surely someone knows? which way does #2 ring go in: ridge up or ridge down?
Vertigo
Postby AceSniper » Sun Sep 20, 2009 10:14 pm
Im sure its ridge down, but don't take my word for it
AceSniper
Postby jaypines » Mon Sep 21, 2009 8:57 am
there will be tiny mark stamped on the end of the rings that says what number or size or brand logo.. that will be up position.
jaypines
Postby no_8wire » Mon Sep 21, 2009 2:55 pm
If you can wait I will have alook at my BGB when I get home. Has all toyotas steps for rebuilding a 4age including ring alingment etc.
no_8wire
Postby Vertigo » Tue Sep 22, 2009 8:55 pm
thatd be great, thanks. post here so everyone can see.
these rings are genuine toyota, and have a very small T in the position you describe, jaypines. im guessing that that side is the one that faces up.
Vertigo
Postby thegreatestben » Tue Sep 22, 2009 9:18 pm
That little 'T' tells you the oil control ring end gap should be between 0.15mm - 0.52mm
thegreatestben
Postby jaypines » Tue Sep 22, 2009 9:30 pm
as in the illustration... code marks faces up.
jaypines
Postby Vertigo » Tue Sep 22, 2009 11:58 pm
great, thanks for the help. appreciate it.
Vertigo
Postby Vertigo » Mon Sep 28, 2009 8:13 pm
just a thought, could you perhaps send me that book? i can put it up somewhere to be hosted, for others to grab too. i assume its on your pc?
Vertigo
Postby thegreatestben » Mon Sep 28, 2009 8:26 pm
It's hosted on a few sites I downloaded it years ago now.
Its the BGB for AW11 MR2's and I also have a 4AGE manual.
Whats your email address - pm me
thegreatestben
