can u put tacho on diesel?
Postby escortman » Sun Sep 20, 2009 9:28 pm
just wondering if i can put a tacho on my buggy, its got a 2.2lt diesel 2L motor, is there any where i can take a tacho signal from?
4x4 toyota blizzard offroader
escortman
Postby Mr Revhead » Sun Sep 20, 2009 10:34 pm
must be as the came with them stock!
prob off the injection pump? dunno, guessing.... but go look at a surf!
btw, its 2.4
Postby escortman » Sun Sep 20, 2009 10:40 pm
o yeh myt have a try with some of them wires, na this is a early edition of the 2L came out of a old hilux tag said 2.2
escortman
Postby Mr Revhead » Sun Sep 20, 2009 10:45 pm
thats a new one on me
Postby strx7 » Sun Sep 20, 2009 11:12 pm
its not a 2L if its a 2.2 its just an L
Postby escortman » Mon Sep 21, 2009 7:47 am
cheers just checked that on wikipedia
i think its got a 2L sticker on the belt cover strange
escortman
Postby AceSniper » Mon Sep 21, 2009 7:10 pm
some use a tacho output from the alternator
AceSniper
Postby 79rolla » Mon Sep 21, 2009 7:13 pm
yeah ud prob have to use altinator pulses (or wahtever theyr called)
past: AE82 FXGT
79rolla
Postby cedwards » Mon Sep 21, 2009 7:45 pm
injector wire??
cedwards
Postby Mr Revhead » Mon Sep 21, 2009 7:47 pm
its mechanical injection
Postby fangsport » Mon Sep 21, 2009 10:21 pm
aftermarket crank angle sensor?
if the engine wasn't fitted with the extra output on the injector pump, it could be your only option.
a wee bit like fitting early non-A/C engine/pump to an A/C body, they don't have the idle-up control.
fangsport
Postby escortman » Mon Sep 21, 2009 10:33 pm
The other option (which I prefer) is to use the existing diesel RPM sensor, and swap out the tachometer and A/C computer for the factory diesel ones. This option is easier to install, the tachometer will have the redline in the right place, and it's cheaper -- especially if your truck has only a tach and no A/C, or vice versa. The downside is that the diesel tach and A/C computer will have to come from overseas. If you decide to go this route, find the two blue wires coming from the same connector as the fuel cut solenoid. The solid blue wire gets connected to ground, and the blue/white wire goes to the RPM signal wire
found that from this site http://vpizza.org/~jmeehan/toyotadiesel/ , will have to check it
escortman
Postby fangsport » Mon Sep 21, 2009 10:55 pm
escortman wrote:The other option (which I prefer) is to use the existing diesel RPM sensor, and swap out the tachometer and A/C computer for the factory diesel ones. This option is easier to install, the tachometer will have the redline in the right place, and it's cheaper -- especially if your truck has only a tach and no A/C, or vice versa. The downside is that the diesel tach and A/C computer will have to come from overseas. If you decide to go this route, find the two blue wires coming from the same connector as the fuel cut solenoid. The solid blue wire gets connected to ground, and the blue/white wire goes to the RPM signal wire
the above only relates to an injector pump with those outputs.
many early L injector pumps either don't have the RPM output or A/C idle up.
early NZ new 2wd utes often have neither.
fangsport
Postby matt dunn » Mon Sep 21, 2009 11:54 pm
and a lot of the jap import van stuff, the base models, dont have the sensor or provision for it,
Like my 1998 Hiace doesn't have a tacho or the sensor for it,
( or passengers sunvisor, rear demister, fuel flap cable, and heaps of other normally fitted stuff)
