hey has anyone use a gizzmo cam fc before are they any good only wanting the air fuel controlling side of it how does it stack up against the apexi safc2
thanks in advance
Let me guess, you have a Caldina GTT.
I strongly recommend you to stay away from any piggyback.
Caldina3SGTE wrote:Let me guess, you have a Caldina GTT.
yea i do whys that?
Coz when you take away fuel it advances the ignition timing and if you trying to put in fuel it retards the timing. Your timing will be all over the place. It's really a band-aid solution, it's probably fine if you have a honduh with minor mods but for a caldina which is pretty fragile due to high compression and skinny rods, I would avoid piggy back.
RomanV wrote:Hmmm, never seen that MAP-ECU before...
Could be just what I need, cheers for the link!
