Brakes spongy when engine running yet fine with engine off..
Postby MercuryFree » Tue Sep 22, 2009 8:29 pm
Hey all,
I've managed to fail a warrant for my brakes being too spongy, even though they perform just as well as they should. Conventional wisdom would suggest air in the lines, so I bled them with new fluid but did not help (have now bled lines three times, twice with car off once with it on (but not engine running) ).
The brakes work 100% fine, and are hard as a rock when pressed with the car off, but are 'spongy' up to about half duration of the brake pedal, tightening up after this.
Any advice? Google reveals many people with the same problem, but no hard solutions anywhere. My brake system does not 'lose' fluid.
Oh, car is a 1996 SS3 Celica, 4 disc w/ ABS.
Any help would be 1000 times appreciated
MercuryFree
Postby gasman » Tue Sep 22, 2009 8:45 pm
could try replacing your rubber lines with new ones if they are a bit old. ore even better got for some braded ones
"What can possibly go wrong?"
gasman
Postby tsoob » Tue Sep 22, 2009 8:53 pm
yeah sounds like u got a leak some where could be vac or hydraulic check both
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby lucasthefallen » Tue Sep 22, 2009 10:17 pm
pump it up with the motor off so it goes rock hard. hold the pedal down hard while starting the motor. if it slowly sinks to the floor thats normally a good sign that the booster is ok.
Need Service or Repair work done? send me a PM
lucasthefallen
Postby postfach » Tue Sep 22, 2009 10:17 pm
something wrong with the booster perhaps?
postfach
Postby matt dunn » Tue Sep 22, 2009 10:20 pm
postfach wrote:something wrong with the booster perhaps?
or perhaps there may be nothing wrong with it at all.
How spongy is spongy?
How does it compare to other toyota's for pedal feel?
Postby fivebob » Tue Sep 22, 2009 10:21 pm
Not from the symptoms described, more likely a worn out master cylinder.
Postby MAGN1T » Tue Sep 22, 2009 11:21 pm
Well it's not a mitsi, but with a mitsi and ABS you bleed the brakes with the motor running.
Otherwise they stay spongey.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby pc » Tue Sep 22, 2009 11:43 pm
Sounds likely... with the engine running the booster is working as well and that might be enough pressure to have the master cylinder leak. (leaking internally).
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby MercuryFree » Tue Sep 22, 2009 11:43 pm
lucasthefallen wrote:pump it up with the motor off so it goes rock hard. hold the pedal down hard while starting the motor. if it slowly sinks to the floor thats normally a good sign that the booster is ok.
OK just tried that, it sunk slowly to the floor in a non-broken feeling manner, so that's a plus (looked up how much boosters cost to replace, ooooouch) 8O :lol:
I've never driven another toyota, amusingly enough...but it's spongier than any of the other cars (around 5-6) I've driven that I can recall. I don't even remember it getting spongy, so I assume this problem has crept up over a few days or weeks at some point so that I was used to it
Will try and get toyota or brake shop to check it out tomorrow I guess, master cylinders aren't that cheap to replace I imagine? Sigh. This car has been on the whole worry free and this current warrant has run me $900 so far and counting...sigh.
Thanks for the help guys (although if anyone has anything else feel free to speak up :) )
MercuryFree
Postby Lloyd » Tue Sep 22, 2009 11:48 pm
Could be a picky WoF place too, Prado brakes and the like feel a little bit like something is wrong if you're not used to them too. If you can pump it up so its hard, leave it off for a moment and then reapply pressure and its no lower then chances are they're fine
Postby iOnic » Wed Sep 23, 2009 7:49 am
How old is your brake fluid?
Postby MercuryFree » Wed Sep 23, 2009 2:12 pm
iOnic wrote:How old is your brake fluid?
It was probably old enough to need changing anyway, not sure as to the exact age, but having bled them three times now there shouldn't be much if any of the old stuff left in there I'm thinking?
MercuryFree
Postby iOnic » Wed Sep 23, 2009 4:50 pm
Nah if you're bled it that much most of that crap will be gone. Was just thinking the fluid may have been saturated with water which was causing vapor locks and the spongy feeling in the pedal (didn't really read the thread fully so I may have missed something) :oops:
Postby Snaps » Wed Sep 23, 2009 7:12 pm
I get the same thing in m supra, brakes go rock hard with the enigne off, with the engine on they feel spongey. Though they felt less spongey after swapping the brake lines for braided.
I think it's normal.
Cheers,
Brandon
2000 ZZT231 Manual Toyota Celica
Snaps
Postby ®usty » Wed Sep 23, 2009 8:26 pm
didn't you change your brake pads a while or something? bleed them properly??
®usty
Postby rollaholic » Thu Sep 24, 2009 7:51 am
if you put your foot on the brake with moderate pressure while the car is running and the pedal gradually sinks down to half travel or lower then i would be looking at a master cylinder. the seals wear and fluid is able to bypass them which can cause this symptom.
they arent super expensive, around 150 retail for something from repco or similar
if you do decide to replace it, it needs to be bled in a vice or something before you install it - may pay to have someone who knows what they are doing handy (if you dont that is)
Postby Flannelman » Tue Sep 29, 2009 8:21 pm
had this issue in my old falcon, had the master cylinder honed and rekitted, brake pedal is awsome. no more half pedal before brakes work
be cheaper to replace the master cylinder than to rekit, cost me $180 for the work done
Flannelman
formerly known as Affroman
Postby Dell'Orto » Thu Dec 31, 2009 5:07 pm
Now I'm having this issue too :evil: AE101 20v Non ABS. However in my case I'd just removed the engine to do various bits and pieces, and have replaced all the brake lines/rotors/pads etc. I've bled the brakes up a couple of times now and no air comes out at all, with the car off the pedal is perfect but as soon as you turn the car on the pedal turns to mush.
Before taking it off the road to do this the brake pedal was fine. Also should mention that when you pump the, the revs rise ~1000rpm
Postby B_giB » Thu Dec 31, 2009 5:56 pm
Had same problem in my 101, bleed the hell out of it, did nothing. Turns out my pads where that low :oops:
Replaced pads, Mint again
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
