20valve bogging down on hard throtle ....
Postby FLESHAXXE » Thu Oct 08, 2009 5:08 am
Recently my 20v levin has been idleing between 1100-780rpm.....during normal driving it's ok but as soon as I go hard on the throtle it is "bogging down" like if it's starving for fuel.....I have tried a gas treatment by Prestone recently and this has not helped....I was also using shell gas ....is anyone familar with this problem....Thanks..
FLESHAXXE
Postby Rick » Thu Oct 08, 2009 6:13 am
Try searching 20v hesitating, some blacktops seem to suffer from it.
Postby headshotnz » Thu Oct 08, 2009 3:10 pm
my silvertop has done this since i owned it. i got used to it...
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Bling » Thu Oct 08, 2009 3:26 pm
What fuel you running? run 98
Postby FLESHAXXE » Fri Oct 09, 2009 4:25 am
over here we realy don't know........all I can tell you it's shell vpower ......
FLESHAXXE
Postby FLESHAXXE » Fri Oct 09, 2009 4:28 am
We really don't know but I think it's around 92........I'm planning on taking out the gas pump and inspecting the fuel tank and the filter......
FLESHAXXE
Postby BigDon » Fri Oct 09, 2009 8:41 am
Potentially a O2 or knock sensor issue, which are common problems that cause this. Have you checked the fault codes?
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby sergei » Fri Oct 09, 2009 8:46 am
FLESHAXXE wrote:over here we realy don't know........all I can tell you it's shell vpower ......
on side note vpower is such a joke, I wouldn't ever put in a ferrari if I had one. It is same regular 95, has nothing special about it.
Try using 98, and see if it helps.
Postby Mr Revhead » Fri Oct 09, 2009 8:47 am
where are you?
Postby wishihadaTE27 » Fri Oct 09, 2009 11:40 am
oz id guess.
wishihadaTE27
Postby Mr Revhead » Fri Oct 09, 2009 11:42 am
ah, old posts sat barbadoes.
which means your fuel is prob american, or using american ratings
which measn your 92 is not the same as 92 here, it will be close to 96
Postby FLESHAXXE » Sat Oct 10, 2009 6:38 am
I will try changing the Knock Sensor and see what happens.....Barbados is where I'm at.....Thanks guys...I will let you know what happens....
FLESHAXXE
Postby rollaholic » Sat Oct 10, 2009 7:07 am
i would check the fault codes before changing anything
Postby MAGN1T » Sat Oct 10, 2009 7:34 pm
Your best bet would be to hook up a voltmeter to the oxy sensor and take a note of what readings you get Is the back of the car sooty looking?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby 96bzg » Sun Oct 11, 2009 5:01 pm
hay i have the same problem i only norm get it between 2-3 grand and have only got it since new exhaust back of exhaust is soty what does that mean do i needa get new oxy sensor ?
96bzg
Postby RS13 » Mon Oct 12, 2009 12:28 am
Check fault codes.
RS13
Postby nmcgowan » Mon Oct 12, 2009 2:52 pm
Have a look through my posting. It has a number of different things you could look at, my problem ended up being a failing fuel pump that couldnt hold pressure reliably.
http://forums.toyspeed.org.nz/viewtopic.php?p=744698#744698
It's likely it will boil down to one/some of these being the cause but always check for trouble codes first as that can tell you almost straight away if its a sensor thats at fault.
In no order of preference.....
1) Worn Distributor rotor or cap.
2) Air Flow meter (ST) or MAP Sensor (BT)
3) O2 sensor.
4) Water temp sensor.
5) Faulty ECU - quite common for capacitors to leak.
6) Fuel related issue i.e. clogged filter, fuel pressure (pump), injectors etc
7) Broken or faulty plug leads and/or plugs.
8. Starter signal wire to ECU.
9) Vaccuum leak.
10) Faulty ignitor or coil.
11) Bad earth.
12) Timing is wrong or belt has jumped a tooth.
Behold the mighty SN1FTR.
nmcgowan
Postby pc » Mon Oct 12, 2009 5:41 pm
TPS faulty?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby 96bzg » Tue Oct 13, 2009 7:25 pm
hmm i have new trd leads and have just brought new plugs to see if it was that also have new fuel filter that will be going in dis weekend hopefully that fixes it otha wise ill av to get som one to look at it and im really fussy on who i let touch the car as have had rummys b 4 ....
96bzg
Postby 96bzg » Tue Oct 13, 2009 7:26 pm
what do you mean trouble codes how do you check them ?
96bzg
