can any one tell me why the fcuk this has happened?????????
has any one else had this problem??????
Thanks Tyler
fivebob wrote:It's melted because it overheated.
Are those genuine Toyota leads?
fxgt race wrote:If the temp gauge was only just over halve way when you stopped it should be ok , so hopefully the engine will be fine. check water in oil etc, put new leads on and give it ago
loudstealthGT-Four wrote:fivebob wrote:It's melted because it overheated.
No there Champion.........
It didnt overheat the temp gauge went just over half so i stopped???
loudstealthGT-Four wrote:oh ok thanks. (really hoping i havent $&#$% the motor)
fxgt race wrote:Best you chip at what is left on the spark plug with a screw drive and hook a hose to a vacum cleaner that will fit down the spark plug hole to suck out the crap. A new leed and she be sweet.
