id have the vortex clutched so it is completely disengaged one the turbos spool up past whatever its boosting (say 8psi) and have a flapper ( one way valve) in the system to reduce lag on the supercharger (so it doesn't have to pressurize the whole system and prevents turbo compressor surge (in theory at least) and once the supercharger is disengaged it would reduce work on the engine and the flap would prevent boost leaking out the supercharger (compressor surge)
the flap may need to be replaced by 2 one way valves depending on how good of a seal could be produced by the flap
hope all that makes scents.
thoughts? would it work?
