tsoob wrote:flat spot on the tyre? handbrakies at all bro?
bring it down if u like will spin it up
Loudtoy wrote:Could be that you just have a bulge in one of your tires, that will make it feel like that as well
79rolla wrote:also check you don't have a buildup if dirt ect on the inside of the rim, that can put a wheel out of balance by quite alot..
79rolla wrote:also as tiers wear the balancing can be affected depending on the imperfections/defects in the tier (is worse on cheaper tiers)
Bazda wrote:Did you manage to put on the bigger brakes?
cat007 wrote:Well the tyre burst last night so no need to get it balanced haha
Have got spare on but will need a replacement
Nick if you're reading this - do you have, or can you get some of those light truck tyres like what I bought off you last time? I can't remember the size - can you? haha
tsoob wrote:
yeah man i can get it you just need 1? or want to do the pair.
Nick
Nick
Just 1 for now. The other seems to be fine
