C56 into ae101, BT headers on ST engine, clutch questions
Postby headshotnz » Mon Oct 19, 2009 8:51 pm
After a long wait i finally got some money together for a new gearbox.
I went to pick a part today and there was a ae111 s/s levin/trueno.
So i grabbed the c56, the headers and the cam cover... :D
Ill be starting the swap in the next few days, just got to buy a new clutch.
Also what type of clutch should i get? Was going to get one from repco as i can get good prices :) and when they ask what year levin i have (assuming there wanting the gearbox (c52/c56/c160/e58 etc etc) code) should i tell them its made after 93 (year c56's came out, i think.)
Is there any thing else i should know before doing the swap?
Also is it worth putting the blacktop headers on, and if so, do i use the 4-2 section from the BT and use the 2-1 section from the ST or BT? Also is there is dyno charts with this mod?
Cheers guys
EDIT*
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Crampy » Mon Oct 19, 2009 10:40 pm
BT 4-2 section and make a custom 2-1 section (500mm long if I remember correctly, someone will say otherwise), pay attention to the part that goes over the crossmember ie get rid of the squish.
Crampy
Postby headshotnz » Tue Oct 20, 2009 12:15 am
Ah i see.
I cant custom make my own 2-1 section, however i have the ST and the BT 2-1 section. So which would be better to use?
headshotnz
Postby Subway » Tue Oct 20, 2009 12:39 am
Which pickapart did you go to? im looking for parts from an ae111 too haha
Subway
Postby headshotnz » Tue Oct 20, 2009 2:05 am
Subway wrote:Which pickapart did you go to? im looking for parts from an ae111 too haha
Wellington mate, block is there, pistion con rods gone, head there, cams and itb's gone. theres some interior, front seats look pretty good too. its white with frontal damge, back lights arnt the real cool looking ones.
headshotnz
Postby Flannelman » Tue Oct 20, 2009 2:11 pm
use BT, there bigger.
Flannelman
formerly known as Affroman
Postby Crampy » Tue Oct 20, 2009 5:49 pm
I heard ( well rather read) a rumour that the pressure plate from a 2ZZ Ceilca will also fit on a Blacktop Flywheel and has more clamping pressure. If so, would be a good option
Can anyone tell me if this is BS or true. I did read it on Twincam.org forums :?
Crampy
Postby AceSniper » Wed Oct 21, 2009 8:59 pm
it fits as iv used one when 4age wasnt in stock. but dont know about clamp guess if the part number differs it is. One I had was exedy and the casting was thinner/lighter
AceSniper
