Passengers window come off rail at bottom
Postby .:O4AGTZ:. » Tue Oct 20, 2009 8:47 pm
In the missus corona the passenger side window has come off the rail that it usually sits snug in at the bottom. Are you able to put the window back into this? I presume that once it is out it is out as you wont be able to close it around the window again...someone must know!
.:O4AGTZ:.
Postby Mr Revhead » Tue Oct 20, 2009 9:08 pm
yes you should be able too, there's usually a rubber insert in there.
use an adhesive.
the glass is sold with that metal section attached
Postby .:O4AGTZ:. » Wed Oct 21, 2009 8:52 pm
yes there is a rubber insert put if i put the window in with some adhesive wont it just hold on to the rubber and pull that out? or i could go all out and glue the rubber to the rail and the window to the rubber haha
.:O4AGTZ:.
Postby sergei » Wed Oct 21, 2009 9:48 pm
you could epoxy it without rubber.
